brake pads
Started by Toledodude1973, 07 December 2015, 19:21:16
Quote from: GastronomicKleptomaniac on 07 December 2015, 21:11:27
Both MrsGK and I tend to drive like we have eight seconds to save the planet, the MV6 has TC pads on and theyre more than good enough for us.
By Omega standards anyway....
Indeed, in the budget end, TC pads are by far the best. At £15 for fronts, why mess around?
Quote from: TheBoy on 07 December 2015, 21:14:45
Can't argue with that ;)
robson
surely if the pads are down to the sensor the light would stay on.
Quote from: robson on 08 December 2015, 09:12:55
Yes, once the track on the sensor has worn through, it should stay on. A light that comes on when you press the pedal sounds to me more like it's fluid level, TBH. Actually, the brake wear sensors bring up a message on the MID, not the light on the instrument panel. (on my facelift, at any rate)
Quote from: Kevin Wood on 08 December 2015, 09:42:04
GLS put a light on for pads, anything else should pop a message up. :-\
Could simply be that all the pads are getting low rather than the sign of a significant issue :y My mk2 Granada used to put the fluid light on before the pad warning, which rather defeated the purpose ;D
Mr Gav
As others say, there will be a message on MID if it`s the pads that are worn.
As for the pads themselves my vote is for OE, not cheap but worth the money IMHO.
Quote from: Mr Gav on 08 December 2015, 18:53:11
I use OE on one Omega and TC on the other.
As OE are now quite dusty (like TC ones), I'd say the biggest advantage is that they bite better when the car has been left for a day unused, whereas TC ones appear to need to be used gently first before they have any bite.
Diamond Black Geezer
I've got TC on mine and would probably say the same. I feel there's a definite increase in braking efficiency/feel after they've 'warmed up'  :)
robson
Is TC trade club and OE original equipment? If so I am confused.
Quote from: robson on 09 December 2015, 15:29:15
Yes. And why confused? The OE pads are what was fitted in the factory. The TC are a slightly cheaper GM alternative.  :y
I think the logic is if you make the (TC) 'decent-enough' pads cheap then there's no excuse for anyone not having gm pads fitted. Just acquired a set of the genuines, too (part number 9195077) so whenever I get to fit them, we'll see how they perform on the old girl. Got TC ones with barely 6k on them currently and personally very happy with them, but know a few have said you can tell the difference, so we shall see  :)
robson
Thanks for the clarification I didnt realise that GM supplied two types.
omega2018
trw disks and pads been good for me. £8.50 for the pads £17.50 for the disks.  plus £5 for a can of hi temp spray paint for the edges.
Quote from: robson on 09 December 2015, 21:11:11
Nor did I until relatively recently. It's something worth keeping your eye out for, actually, as almost all the time Omega GM pads for sale are the TC ones, and rarely any £ difference from just getting them from Main Dealer.. but every now and then the higher-grade ones will slip through. Got mine for £20  :y
robson
confusing isnt it GM obviously dont manufacture pads I wonder where they come from and how do you tell the difference between TC and OE.
