Gunk on the oil cap.
Started by dazza88, 10 December 2015, 19:02:10
dazza88
Hi all, as you know I picked up a 2.6 omega been driving it to and back from work for 3 days now 4 days tomorrow;-) it has sat around since September after m.o.t as the last owner couldn't be asked To put a crank sensor on her,  but any way I've cleaned the gunk of the oil cap on Tuesday and checked it after work today and there is a little bit of gunk there not much but a bit could it be just were it sat around or the really bad cam gaskets leaking every were I'm not sure, runs and drives lovely fans kick in when just over half way also been checking the oil on the dipstick and also looks and feels ok it's pretty fresh oil still. Any one else had this problem thanks all  :y
Darren
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
martin341
It's usually because short(ish) trips specially in colder season. I had it on my mv6 turing fall/winter/spring when my worktrip was about 3 miles. All clear in summertime.
biggriffin
Mayo on filler cap is a sign of short journeys, or castrol oil. Change the oil n filter, use a decent oil (gm) and give it a good run. This is assuming, no sludge in header, if so then oil cooler time.
Hoof'land storeman.
zirk
Yep, don't worry about it, as long as the dip stick is clean. Tends to be worse this time of year as well, cold damp etc.  ;)
Toledodude1973
Had exactly same with my 2.6 when i first got it, no problem after few trips just condensation from big engine :y
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
dazza88
Quote from: martin341 on 10 December 2015, 19:20:54
Sweet thank you, it's also in the oil flum bit as well but will take off at weekend and clean it, but at least that puts my mind at rest plus just spend 80 something on the cam cover gasket kit from vx am going to ring serek up tomoz to see when can squeeze her in  :y
dazza88
Quote from: biggriffin link=topic=133716.msg1714325 :#msg1714325 date=1449775287
Cool thank you just checked coolant and it's just got antifreeze colour in its nice and pink, I'm hoping to get cam gaskets done this weekend or at some time then she will get an oil service and gearbox and air filter ect was just checking before I spend money on it really ;-) but thanks all for your comments makes me fill much better now  :y
EMD
Check all your breather pipes as well . If its been abused then they are likely to be blocked , especially the small pin hole to the breather box .
Omegatitis
dazza88
Quote from: EMD on 11 December 2015, 13:31:40
Thank you, will do ;-). I'm hoping to book it in on Monday/Tuesday with serek, he said he will check all that ;-)
dazza88
Good news after a weeks drive about 25miles a day to and from work I checked the cap and the oil flume today on the cap there was still a little bit but not as much as last time I checked, but the flum bit has only got a little bit up the top apart from that there's hardly any in there the complete flum was full of it around the edges so happy days  :y also cam are getting done Wednesday, then Thursday she will get a service.  :y
Boatboy
I tend to do a lot of short journeys too. I followed advice on here to remove the filler neck and put the cap direct onto the cam cover instead, and that either reduces the amount of mayo produced or just ensures it gets washed off and burnt away quicker.
Still get some under the cap but nowhere near as much as before.
Steve
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
EMD
I mite be wrong here but if your doing short journeys then if you have the filler neck on then at least you can wipe away the gunk BUT if you take the neck away then that would push more gunk into the breather system ?  :-\
Omegatitis
Quote from: EMD on 14 December 2015, 14:07:22
That's about the size of it ;)
Diamond Black Geezer
 :o
Best dig out my filler neck, then! It's not doing much in a box, in a box, in my old bedroom at my parents house!  ;D
Boatboy
The emphasis being on the can of course.
If memory serves the rationale behind the suggestion before was that the neck sticks up in the air thus not getting so hot hence generating extra condensation/mayo rather than just being a depository for the normal amounts. Sounds sensible but could just as easily be small round things.
Of course the real answer is don't do short runs in a big old bus, but as we know that's not always a practical suggestion.
