Author Topic: heater problems  (Read 3467 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
heater problems
« on: 10 December 2015, 19:30:26 »
Hi quick one, the heater is playing up, if car is idling we have no heat, if your cruising then all is fine, whats the problem must be simple?
thanks in advance
www.impactcls.co.uk - Flight Case Manufacture
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: heater problems
« Reply #1 on: 10 December 2015, 19:42:38 »
thanks in advance
Whats the temp gauge doing during all this.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: heater problems
« Reply #2 on: 10 December 2015, 19:43:54 »
Time to be flushing the matrix, and possibly replacing the engine thermostat.
Impact Pete
  • Derby
Re: heater problems
« Reply #3 on: 10 December 2015, 19:44:44 »
thanks in advance
All normal
Impact Pete
  • Derby
Re: heater problems
« Reply #4 on: 10 December 2015, 19:45:34 »
Matrix flushed a few years ago so worth a try I guess thanks
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
Re: heater problems
« Reply #5 on: 10 December 2015, 19:46:12 »
Is there enough coolant in the system?
Impact Pete
  • Derby
Re: heater problems
« Reply #6 on: 10 December 2015, 19:54:47 »
Good point should of checked that first! Ill blame that on lack of sleep
Impact Pete
  • Derby
Re: heater problems
« Reply #7 on: 10 December 2015, 20:00:53 »
Well there's my heater problem fixed the header tank was completely empty with a cold engine so now I obviously have other issues! Possible only a simple water leak but who knows till I get some day light
Re: heater problems
« Reply #8 on: 11 December 2015, 10:26:48 »
Check the HBV ;)
EMD
  • Noofhampton
    • 95t
Re: heater problems
« Reply #9 on: 11 December 2015, 13:15:54 »
Or your winter pack pump thingie  :-\ I believe this on mine is to be the culprit , need to bypass it somehow  :-\
Omegatitis
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
Re: heater problems
« Reply #10 on: 11 December 2015, 17:32:39 »
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: heater problems
« Reply #11 on: 11 December 2015, 20:06:54 »
If winter pack pump is the one that sits below header tank then by passing it must be fairly simple as not all Omegas have them in the first place,mine certainly hasn't!
