Author Topic: XENON Drivers light  (Read 3879 times)
dazza88
  • luton (bedfordshire)
    • 2001 2.6 v6 auto omega
XENON Drivers light
« on: 10 December 2015, 20:54:25 »
Hello again all, sorry for all the questions tonight, I popped to mcdees with the miss but noticed the drivers side light had like a shadow blocking the brightness of the XENON when looked at it the beam on the light unit it seems to have dropped and was pointing down the silver bit on the eye light bit it seems like it needs to go up but the lights have not got a light level switch in the car, any suggestions thanks again everyone  :y
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: XENON Drivers light
« Reply #1 on: 10 December 2015, 21:10:31 »
You have a broken adjuster.
There is a guide, but I believe you won't be able to but the parts mentioned.
dazza88
« Reply #2 on: 10 December 2015, 21:12:30 »
I think I see that in the guide but I weren't sure if it was for normal lights  :-[
ted_one
« Reply #3 on: 10 December 2015, 21:23:06 »
Have just received some adjusters made from a solid block of silicone. came from Poland,come with a life time guarantee,and therefore should last longer than the Omega ::)
dazza88
« Reply #4 on: 10 December 2015, 21:31:14 »
Oh right cool cool, would I have to separate the lens from the unit to put the block in or is there a different way,  :y
powerslinky
« Reply #5 on: 10 December 2015, 21:34:13 »
Which omega are you gonna trial  them on Ken ?  & is  there a link to the "supplier" we can have a butchers at  . . .
Or are "Nitro International Importers" gonna be the sole agents . .  ;D ;D ;D
  • Chatham, Kent
« Reply #6 on: 10 December 2015, 21:39:30 »
Removing the lens is easy: place the entire lamp in the oven for 5minutes at 100degrees, and you will be able to push it off with your fingers. I'm currently halfway through doing a batch of these, and that is quick, easy and effective. I have been stripping the bulbs, motors and ballasts before doing this. I did try a heatgun, but it takes longer and doesn't heat the whole job efficiently - too much faffing about for me. You do need to ensure that you don't get the adhesive over the reflectors, but that's just a case of cutting any stringy bits with a sharp Stanley or single-edged razor blade.
Put the lamp back in the oven when you've refitted the lens, and you'll be able to jiggle the lens around for a proper fit.
dazza88
« Reply #7 on: 10 December 2015, 21:42:52 »
Oohh yeah I never thought of the oven on my last omega with the normal bulbs I done with a heat gun and it was a nightmare lol, oh right let me know when you have some available please  :y
ted_one
« Reply #8 on: 10 December 2015, 21:47:51 »
Not sure how to do the link.....so on that well know auction site..item 281256289565, £8.00 each plus £3.00 p&p for as many as you need :y they look OK so fingers crossed.
ted_one
« Reply #9 on: 10 December 2015, 21:53:58 »
Going to get myself a nice Reliant van and nip over to Poland.....seems that you can get most things Omega over there ;)
dazza88
« Reply #10 on: 10 December 2015, 21:54:24 »
They look pretty good although in the discription it said hella would these still fit for the Xeon lights if so I'm going to order some  :y I noticed there in Hatfield not far from me don't suppose you know if can collect them
  • Chatham, Kent
« Reply #11 on: 10 December 2015, 21:55:10 »
It will be interesting to see how they compare to the aluminium ones, which aren't quite as tight a fit as the original broken parts.
ted_one
« Reply #12 on: 10 December 2015, 22:49:09 »
They look similar to the Ali ones but have nothing to compare with.Ermm left another set of headlights on the back seat when I left your place Durr!!! ::)
ted_one
« Reply #13 on: 10 December 2015, 22:52:44 »
The items come from Poland,it must be the Polish Hatfield ;D ;D took a week to come :-\
dazza88
« Reply #14 on: 10 December 2015, 22:56:18 »
 ;D ;D :D maybe hehe, I've ordered a set  :y
