vectra c sidelight bulb !!!!
Started by andy76mv6, 12 December 2015, 11:15:17
andy76mv6
Trying to change drivers side sidelight bulb got bulb out no bother but replacement bulb is just the bulb not the holder. Can't get old glass bulb out of holder don't want to break it! Help please!!
andy76mv6
It's just a wedge bulb I have still can't figure out how to remove old one!!!
Quote from: andy76mv6 on 12 December 2015, 11:15:17
I removed the airbox and the associated gubbins in order to change the headlight (dip) bulb. Easy enough fix.
andy76mv6
Access is manageable, old bulb is out but I need to take the old glass bulb out the metal carrier to replace new wedge bulb? Just can't get it out metal parts!!!
andy76mv6
My stupid mistake!! I've been trying to dismantle the full beam bulb( total teat ) father in law returned with car swapped high beam bulb for one I had in my boot, no change proper inspection unveils small bulb underneath!!
5 mins all done.
Thank for your wasted time guys.
Make sure you don't touch the main or dip beam bulbs as the grease from your skin will cause the glass to fail
Quote from: Marks DTM Calib on 12 December 2015, 21:05:10
I suspect this warning may be a bit late :-\ ::)
andy76mv6
Replaced high beam bulb with new so got away with that!
