Author Topic: Sensor/sender units  (Read 5642 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Sensor/sender units
« on: 19 December 2015, 19:21:15 »
The recent overheating issue on my Elite has set me thinking[not something I do well :D]On the coolant bridge there is a sender unit with a single wire which I understand is for the temp gauge on the instrument panel.Then there is a sensor with a plug,what does this control/send a signal to?Surely if it's sending a signal somewhere then when the temp gets to or near critical it should then do something to "protect"itself/the engine?Reason I ask is that although temp gauge needle on mine was banging off the stop at top of red zone the engine was still running smoothly with no issues other than the temp being way over the top.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Sensor/sender units
« Reply #1 on: 19 December 2015, 19:27:00 »
The single wire one is for the gauge. The other is for the engine ECU and is more sensitive/accurate. And yes, you could drive the gauge from the ECU, but German engineers don't think like that ::)
« Reply #2 on: 19 December 2015, 19:31:26 »
..... And yes, you could drive the gauge from the ECU, but German engineers don't think like that ::)
There's only one sender for both gauge & engine on my Smart  ;) ;)
« Reply #3 on: 19 December 2015, 19:33:04 »
The other sensor is the ecu coolant temp sensor :y the ecu then manages the fans, which as a backup have their own thermoswitch in the radiator. This too can fail, but the ecu should still trigger the fans if the block starts to cook...
Any doubts about either then replace both sensors. You can also follow the fan test guide to be sure that they are working as they should.
In your example I would start with the fan test, then replace the gauge sensor if the fans check out fine. Any further issues then change the ecu sensor :y
Obviously for ease of access vs cost,  you might as well replace both. And unlike crank and cam sensors, pattern sensors from reputable local motorfactors are usually reliable. Not sure how much genuine gm sensors are, but when it failed on mine, the genuine ecu coolant temp sensor was in stock and about £12 iirc :y
Generally speaking, if the coolant has been changed regularly from new with the correct mix then the sensors should be pretty bombproof :y
« Reply #4 on: 19 December 2015, 19:33:39 »
Which was designed by the Swiss :D
BazaJT
« Reply #5 on: 19 December 2015, 19:36:25 »
I thought the sensor would send to the ecu but wasn't sure.So if the ecu gets the signal that the temp is way out of range i.e.overheating shouldn't it take steps to protect the engine,shut it down or something?
BazaJT
« Reply #6 on: 19 December 2015, 19:37:07 »
Must learn to type faster :D ;D ;D
BazaJT
« Reply #7 on: 20 December 2015, 12:45:13 »
Where would I find instruction on doing fan test? I've had a look but being a full on numpty with computers I can't find one. :-[ :-[ :-[
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 20 December 2015, 14:12:58 »
That's why there's a head gasket  :y designed to be the first thing to let go before engine damage.
RIP Paul Lovejoy
« Reply #9 on: 20 December 2015, 15:08:15 »
The the ecu input is the back up... fans are independently switched by the thermoswitch on the radiator, as is the radiator coolant pump (v6 only iirc). The ecu can also switch the fans on according to engine (rather than radiator) temp and also if the aircon is on...
Similar issue to the one you describe, yours being a late 3.0... http://www.omegaowners.com/forum/index.php?topic=133058.msg1704776#msg1704776
Fan test here... http://oldsite.omegaowners.com//forum/YaBB.pl?num=1295795115
Hth :y
Webby the Bear
  • Northampton
« Reply #10 on: 20 December 2015, 15:26:02 »
S'what I was told in college  :y
RIP Paul Lovejoy
« Reply #11 on: 20 December 2015, 17:45:03 »
Webby the Bear
  • Northampton
« Reply #12 on: 20 December 2015, 18:08:57 »
Could be wrong and sorry to op if I am  :y
RIP Paul Lovejoy
BazaJT
« Reply #13 on: 20 December 2015, 18:16:34 »
Thanks for those links HKT.The rear fan does seem to operate as it should since I replaced fuse in fuse box below steering wheel,but don't know about front fans.Still don't know how it stood mot without the fuse and without overheating.However weather permitting I'll do the fan test over Xmas and go from there.
  • Chatham, Kent
« Reply #14 on: 20 December 2015, 18:59:34 »
Surely it's more of a necessity to keep the oil and water in their respective jackets when the head and block are separate? After all, with an aircooled two-stroke engine you can lap the head and cylinder block together and eliminate the head gasket.
