Author Topic: disc/pad change  (Read 5850 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
disc/pad change
« on: 21 December 2015, 16:45:23 »
I plan to change discs and pads front and rear on my F/L 2.6 when i can muster the energy! Keith ABS has kindly supplied discs/pads for me , are there any other bits worth getting before hand to make  job of it? thanks for help
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: disc/pad change
« Reply #1 on: 21 December 2015, 17:47:25 »
Handbrake shoes if you're doing the rear. They might be OK, but they might be like mine and not survive removal of the disc. Only adds about £20.
Toledodude1973
  • IPSWICH U.K.
Re: disc/pad change
« Reply #2 on: 21 December 2015, 17:53:36 »
Ahh ok Nick,can discs be a cow to remove on rears?
  • Chatham, Kent
Re: disc/pad change
« Reply #3 on: 21 December 2015, 17:58:46 »
Not if you back the H/brake adjusters off. But the shoes are probably original, and the linings are very thin. Mine fell apart, which meant another trip to the factors. You'll never need to replace them again.
Toledodude1973
  • IPSWICH U.K.
Re: disc/pad change
« Reply #4 on: 21 December 2015, 18:01:29 »
Sounds like good advice thankyou Nick :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: disc/pad change
« Reply #5 on: 21 December 2015, 18:14:26 »
As Nick says, fully back off the adjusters, then the discs should come off, though there is often a lip of rust built up where the shoes have not rubbed, which hinders removal. I have found Vx genuine shoes expensive, so bought pattern, but suspect they are not so grabby as original. Have other members found this?
martin341
  • Finland
  • I do my own stunts.
    • '00 3,0 MV6, '00 2,5 V6
Re: disc/pad change
« Reply #6 on: 21 December 2015, 18:18:13 »
I'd also recommend all installation, securing parts to change including handbrake thightening thingi between shoes at the top. Also clean handbrake lever? between shoes at the bottom where the cable attaches.
Toledodude1973
  • IPSWICH U.K.
Re: disc/pad change
« Reply #7 on: 21 December 2015, 18:41:01 »
Looked at handbrake shoe replacement guide, is it difficult or manageable with patience?
Re: disc/pad change
« Reply #8 on: 21 December 2015, 18:50:08 »
Not degreasing the drum adequately :-\
martin341
  • Finland
Re: disc/pad change
« Reply #9 on: 21 December 2015, 18:51:14 »
Make the tool for springs or it'll be knuckelbraker and needs balls nerves of steel :)
Re: disc/pad change
« Reply #10 on: 21 December 2015, 20:01:36 »
Very much that one :y
terry paget
    • 3 Astras 2 Vectra
Re: disc/pad change
« Reply #11 on: 21 December 2015, 20:30:24 »
Could be. I use petrol. What do you recommend? Brake cleaner aerosol?
Toledodude1973
  • IPSWICH U.K.
Re: disc/pad change
« Reply #12 on: 21 December 2015, 20:32:50 »
Would carb cleaner on contact surfaces be suitable?
martin341
  • Finland
Re: disc/pad change
« Reply #13 on: 21 December 2015, 20:38:39 »
Brake cleaner, but carb cleaner should also do the trick.
  • Chatham, Kent
Re: disc/pad change
« Reply #14 on: 21 December 2015, 21:13:51 »
It's hardly difficult with a decent pair of needle-nosed pliers, but using a small hook isn't as fiddly.
