Pages: [1] 2 3  All   Go Down
Author Topic: 2.6 non starter  (Read 9705 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
2.6 non starter
« on: 22 December 2015, 18:30:16 »
tried starting the 2.6 today after about 7 months , battery was total dead . fitted new battery but will not start, seems to be that there is no spark as there is lots of fuel coming though, it always started right away before being left , anybody any ideas ,    thankyou
swordfish
  • manchester
Re: 2.6 non starter
« Reply #1 on: 22 December 2015, 18:38:19 »
done the pedal trick and its saying  6364
Re: 2.6 non starter
« Reply #2 on: 22 December 2015, 18:41:36 »
Do it again
swordfish
  • manchester
Re: 2.6 non starter
« Reply #3 on: 22 December 2015, 18:43:45 »
in what way , does that not sound right
powerslinky
Re: 2.6 non starter
« Reply #4 on: 22 December 2015, 18:46:53 »
Pretty sure all 2.6 /3.2 codes begin with a 0     may be worth having a double check on the pedal trick code readout  :-\
0335 would be a prime suspect here IMO
« Last Edit: 22 December 2015, 18:49:16 by Essex Big Al »
swordfish
  • manchester
Re: 2.6 non starter
« Reply #5 on: 22 December 2015, 18:48:57 »
thanks , would the knock sensor cause it not to start
swordfish
  • manchester
Re: 2.6 non starter
« Reply #6 on: 22 December 2015, 18:50:14 »
its hard to know what 0 is from flashes
powerslinky
Re: 2.6 non starter
« Reply #7 on: 22 December 2015, 18:56:40 »
10 flashes = 0     have a look at Gixers video in the maintenance guide
« Last Edit: 22 December 2015, 19:07:01 by Essex Big Al »
amba
  • Medway towns
    • German V6
Re: 2.6 non starter
« Reply #8 on: 22 December 2015, 19:05:39 »
Unless you have put a clean fill of fuel into the tank I doudt if 7 month old will be helping the cause .
Worth rigging up a clean fuel feed from a metal jerry can and see if that produces better results.
A ggod start requires decent plugs /good charge in battery and a clean source of fresh fuel
    • 530D M Sport, 330i Coupe
Re: 2.6 non starter
« Reply #9 on: 22 December 2015, 19:31:23 »
Is the EML just constantly flashing when you turn the key?
swordfish
  • manchester
Re: 2.6 non starter
« Reply #10 on: 22 December 2015, 19:34:24 »
the  orange light with the car and a spanner is flashing the minuet you turn the ignition on
Re: 2.6 non starter
« Reply #11 on: 22 December 2015, 19:35:58 »
Classic immobiliser issue... basically the chip in the key is either missing or wrong...
swordfish
  • manchester
Re: 2.6 non starter
« Reply #12 on: 22 December 2015, 19:41:54 »
so the immobilizer only cuts the spark and not the fuel
powerslinky
Re: 2.6 non starter
« Reply #13 on: 22 December 2015, 20:06:48 »
Try this  . . . sit in the car  . . turn ignition on . . push a  key fob button to do a central  locking reset ( doors lock & then open again)
Take key out  . .  get out of the car & lock using the fob  . . . then unlock using the fob  . . .get in & try to start the car .
Might seem strange  . . .but it has fixed a few with this problem   . . .mine included  ;)
swordfish
  • manchester
Re: 2.6 non starter
« Reply #14 on: 22 December 2015, 21:31:48 »
thanks , tried that still no joy and light still flashing , what next
Pages: [1] 2 3  All   Go Up
