LED lights
Started by EMD, 22 December 2015, 23:42:45
EMD
Buying some outdoor LED xmas icicle lights , never put them up before but the product says ...
QuoteSuitable for indoor and outdoor use, although the transformer should remain indoors at all times.
Where would you put the power wire into the house ?  :-\ Was thinking through the window then close the window as long as that dont crimp the wire  :-\
Omegatitis
flyer 0712
If its an upstairs small window should be ok...... :y
zirk
I normally use the same hole thats used for the Kitchen Supply thats connected to the Street Light outside. ;)
Gaffers
I have one that goes out through a closed pvc window, has done for years without ill effect. You could also get a weatherproof box if you have an outdoor socket..
Quote from: zirk on 22 December 2015, 23:56:34
;D ;D ;D ;D ;D ;D ;D ;D Are you related to STEMO? :P
Quote from: aaronjb on 23 December 2015, 09:17:56
I believe he no longer lives in Liverpool. ;)
Quote from: Doctor Opti on 23 December 2015, 09:34:26
Then he must have stolen a long extension lead before he left!
EMD
All sorted , power wire fed through the window no problem . All ready for the big switch on later  ;D  :y
Omegatitis
Why bother putting a hole in your house? Just bypass the meter.  :)
Tony H
Quote from: STEMO on 23 December 2015, 16:34:46
Is right Steve  :y
