Battery charger question
Started by BazaJT, 27 December 2015, 10:53:34
BazaJT
The battery charger I have is donkeys yonks old,but still works perfectly well.It's a Pro user 4amp,model BCH4 if that means anything to anyone.Question is can I use this on a motorcycle battery or do bike batterys need a dedicated charger?
zirk
Assuming your bike battery is 12v and not 6v it should be fine (or is there a switch on the charger for 6v/12v?).
BazaJT
No switch on charger to alter voltage,however bike battery is indeed a 12v one.Thanks.
martin341
Quote from: BazaJT on 27 December 2015, 13:34:40
...bike battery is indeed a 12v one..
Yep, absolutely safe to use, but i'd recommend disconnecting the battery for charging time.
BazaJT
That's one thing I've always done.I always take battery off anything it's attached to-always been cars before of course-and take battery to charger,not charger to battery.But thanks for tip anyway.
johnnydog
I've recently bought a Ring 8amp smart battery charger for approx £65. Excellent charger - recognises the battery type (gel, wet etc.), battery voltage (6v or 12v) and the level and type of charge needed and charges accordingly during a series of different charge cycles. You can also set your own charging cycle depending on the type of battery (for stop / start in modern cars). Displays the rate of charging, % charge level of battery, battery volts etc at any given time during the charging process. Has a cold charge facility, a facilty to repair a deeply discharged battery, can retain the radio codes during a battery change, and can be left connected to a laid up car to trickle the battery when needed. My old charger wouldn't touch a deeply discharged battery, and just whacked a constant charge in, which I believe can do more harm than good. Well worth the money, I think!
