Some nice ground to air video
Started by 78bex, 08 January 2016, 00:10:02
78bex
From this youtube uploader  :y
Not entirely sure what kind of mount he`s using here  ???
https://www.youtube.com/watch?v=NrTaiyI68z0
How does he adjust the contrast like that, post production maybe
https://www.youtube.com/watch?v=dfY5ZQDzC5s
Mr.OmegaMan
Looking at that landing clip the tyres do get some punishment, Wonder how often they change them?
Broomies Mate
Quote from: Mr.OmegaMan on 08 January 2016, 00:23:01
When they fail the MOT!  :P
Mr.OmegaMan
Quote from: Broomies Mate on 08 January 2016, 00:23:59
;D ;D
Mr.OmegaMan
Some nice illustration of wingtip vortices there!
(And why us glider pilots are trained to be careful when there's a jet movement!)
Aircraft tyres take one hell of a lot of punishment .... they sit at 30-odd thousand feet for hours on end .. at temperatures of -42 C (ish) and very low outside pressures so the tyre expands a lot ... the aircraft descends and the tyre gets "squeezed" back to normal size .. but doesn't warm up much ... it is hanging in the breeze with zero rotational speed when the aircraft touches down at it goes from zero to mega-lots rpm .. the aircraft is doing around 150 mph remember ... almost instantaneously... it doesn't quite do it though .. which is why you get the puff of smoke as the tyre "skids" on spin-up.
The reason they use dry nitrogen to inflate aircraft tyres is also dead simple ... normal air contains moisture .. at altitude that condenses out into water  at the bottom of the tyre, which then freezes... and doesn't melt in the descent ... this is a large weight which would cause extra load on the "spin up" of the tyre as well as a HUGE balance problem that could actually damage the undercarriage/bogies
Tyres are changed when worn down to a specified marker, on the Herc it was the centre tread gone, but are then sent for retreading. A tyre would do about 100-150 landings under "normal" conditions. Rough strips/shale/shingle and sand blowing onto runways in the middle east wore them out faster
Quote from: Entwood on 08 January 2016, 12:22:48
And having handled my fair share of them, are very heavy! Very thick rubber when compared to a car or even lorry tyre
