IE 11
Started by Auto Addict, 15 January 2016, 17:30:25
Auto Addict
Have Microsoft slowed down IE 11 so that you'll use Edge?
Taking about 20 secs to load a tab on Laptop & PC >:(
I like red cars
b4ndit
Auto Addict
I like red cars
b4ndit
Have you got ABP installed. I notice that is killing IE11 currently.
Although that's more on IE startup, rather than going between pages.
Is your IE slow against OOF (which has no ads or 3rd party ad tracking technology enabled at present)?
Auto Addict
I like red cars
Quote from: Auto Addict on 16 January 2016, 17:42:22
What's ABP?
my guess is AdBlockPro .. quite a decent free adblocking "extra" for firefox & chrome .... never seemed to work well with IE for me and does not work with Edge.
Now using AdGuard (paid for) which works very well in Edge and all the others .. so far .. :)
Probably a bit off topic, but I haven't felt the need to switch on my PC for ages.
Auto Addict
Quote from: Entwood on 16 January 2016, 20:17:13
What's ABP?
No, I don't use it.
I like red cars
Auto Addict
Name                Java(tm) Plug-In SSV Helper
Publisher           Oracle America, Inc.
Status              Enabled
Architecture        32-bit
Load time           0.01 s
Name                Java(tm) Plug-In 2 SSV Helper
Status              Enabled
Architecture        32-bit
Load time           0.05 s
Should I have the above enabled - they are at the minute?
I like red cars
They will only really cause significant slowdowns when you initially start IE, although your stats look like they aren't really causing an issue.
Unless they are misbehaving - easily tested by disabling, see if it fixes it.
The primary reason for disabling Java (or flash etc) is for security purposes, due to a constant stream of vulnerabilities.
Are you suffering the same slow page load problem on OOF?
Auto Addict
Quote from: TheBoy on 17 January 2016, 09:51:47
It's the initial load of IE and opening of a new tab that takes 20 secs+. on both the laptop & PC.
Once a tab is open, everything works fine.
Tried disabling Java, made no difference.
OOf works fine once opened.
I like red cars
OK, that sounds like a slow plugin somewhere (or a slow PC, but IIRC, one of yours is quite recent?)
Auto Addict
Quote from: TheBoy on 17 January 2016, 11:42:02
Laptop is about 5/6 years old.
PC is a new Dell, about 4/5 months old.
Strange it's happening on both machines......
It's only started happening in the last week or so.
I like red cars
