Dual Use Kitchen/Home Appliances
Started by Mr Skrunts, 17 January 2016, 10:09:08
When I moved 7 years ago I bought a can/bottle crusher (thats still in its box and unused) so now I am sitting here looking round online wondering if the did a plastic bottle shredder that was affordable.  Then as you do I began to wonder how easy it would be to make one.  First thoughts were a liquidizer or a food pro processor.  Then I wondered if you could get a cheese grater style wheel that would bolt onto a bench grinder then make a frame with a tube to drop the bottle in and push it down with a plunger/plug device with a buit in depth stop so it wouldn't hit the wheel (getting exspensive now and time consuming)
Then from reading the forum posts over the years it seems that a lot of home/kitchen appliances have a dual use, so maybe the liquidizer with a modified blade might do the job.
Started to make a list of other ideas and started a fresh post on next page, Feel free to add to it. :y
Dish washer = Parts washer.
Fridge/freezer = Shrink parts (Slightly) to press fit
Oven = Expands parts (Slightly) to pressfit
Electric mixer = Paint Stirrer
Knife = Emergency Screw driver
Electric chip fryer/basket = Fill with water (add a bit white vinegar) Ideal small parts washer
Other Items
Electric toothbrush = Cleaning alloys or (Dry) Cleaning switches and air vents
Knitting needles (various sizes) = Unblocking gunged up rubber pipes
The kitchen is not my domain.
I believe this space is where women go when they need to cook or clean something for their master. :)
Electric carving knife is good for cutting foam when doing trim work
Quote from: Doctor Opti on 17 January 2016, 11:56:35
Yes, I think we have heard of your domestic arrangements in previous posts.  ::)
I believe a greased rolling pin makes a great arse dildo. ;D
EMD
And i just threw out an old electric tooth brush . I knew it would have other uses  :(
Omegatitis
Quote from: EMD on 17 January 2016, 12:47:47
And i just threw out an old rolling pin. I knew it would have other uses  :(
That's my boy.  :-*
Quote from: STEMO on 17 January 2016, 12:44:00
You speak from experience? :o :o :o
Quote from: Doctor Opti on 17 January 2016, 12:58:45
I'll leave that to your imagination.  :)
Quote from: STEMO on 17 January 2016, 13:39:52
The last thought I want in my head is of a greased rolling pin sticking out of your arse. :)
.....or worse still so far up that it can't be seen.
Too late by the sound of things.  ;D
Steve B
What about splinters  :-\
