Author Topic: Aircon problem...need help!!  (Read 2872 times)
Omeganewbie
  • Norwich
    • Omega 2001 2l Auto
« on: 18 January 2016, 19:05:27 »
Hi, im really hoping someone can help me
I have a 2001 omega 2l auto.
My aircon was blowing cold when I bought the car, then for about a week the power to the control panel would go off after about 5-10 minutes of driving and now nothing. There are no lights on the climate control panel at all.
I took it to my local garage who checked all the fuses and connections and could find nothing wrong. I then took it to kwikfit to get it regassed but they said the control panel was broken, so I ordered a new one and had that fitted but still nothing.
I have read online that there is a low pressure cut off valve on the power relay which would suggest it would need regassing but my local garage think I'm wrong?
Any help would be great
Thx
« Last Edit: 18 January 2016, 19:20:09 by Omeganewbie »
Re: Aircon problem...need help!!
« Reply #1 on: 18 January 2016, 19:12:46 »
Have you checked the fuses?
Omeganewbie
  • Norwich
« Reply #2 on: 18 January 2016, 19:16:38 »
As I said above my local garage checked all the fuses and connections and found nothing wrong.
« Reply #3 on: 18 January 2016, 19:24:50 »
Any other electrical items not working?
powerslinky
« Reply #4 on: 18 January 2016, 19:28:27 »
Seems strange that climate panel is not doing anything  . . .more likely electrical than aircon fault at this stage IMO
Also , personally I would not let that well known bunch you mentioned  anywhere near one of my cars ,
Especially the aircon :o :o :o
It  not only needs filling it needs checking/testing for leaks   & cleaning    out at the same time . Not a job for those you
mentioned  . . .only my opinion of course ;) ;)
Same sort of price to have done by an air con specialist  ;)  but as said climate control would still switch on  electrically for heat etc
HTH   :y
« Last Edit: 18 January 2016, 19:31:37 by Essex Big Al »
« Reply #5 on: 18 January 2016, 19:30:49 »
Any flickering when it cut out?
I wonder if a) it was properly plugged in, and b) if it has actually been replaced :-\
powerslinky
« Reply #6 on: 18 January 2016, 19:33:10 »
2 good points . .  who replaced the panel ?
« Reply #7 on: 18 January 2016, 19:34:26 »
Omeganewbie
  • Norwich
« Reply #8 on: 18 January 2016, 19:38:35 »
My local garage in norwich just finished switching out the control panel and I watched them plug everything back in and check it over but still no power at all.
Has anyone else heard about a low pressure cut off switch that could cause the power to switch off to the aircon?
Omeganewbie
  • Norwich
« Reply #9 on: 18 January 2016, 19:40:48 »
On the central panel the radio/CD is working fine as are the hazards and everything else electrical that I can see.
powerslinky
« Reply #10 on: 18 January 2016, 19:44:27 »
I have had 2 omegas with aircon not working due to leaked out gas etc.  . . .before being fixed . . but climate panel still worked .
IMO low gas in the system would not shut down the whole climate system  :-\
Omeganewbie
  • Norwich
« Reply #11 on: 18 January 2016, 19:47:50 »
OK, so if it's electrical and I've already switched out the control panel and had all the fuses and wires checked, what other electrical components are left to check?
powerslinky
« Reply #12 on: 18 January 2016, 19:53:35 »
Not too hot on electrics  . . but there are plenty on here who can help you. Someone will be along with advice sooner than later.  Logical answer would be no power to the climate panel  . . .but why,  where or what it is fed from I am unsure :-\ :-\
« Reply #13 on: 18 January 2016, 20:04:22 »
Check the sodding great big 30A fuse on the top left of the cabin fuse box... controls the entire climate system ;)
