Author Topic: Battery Charger?  (Read 3398 times)
fcc-pt
  • Portugal
    • Omega B Caravan MV6 3.0
Battery Charger?
« on: 20 January 2016, 16:31:30 »
Hi, according to battery charger specs some may not be suitable to my battery.
My battery specs are: 12 V 74A 850AH.
Which one should I get?
Re: Battery Charger?
« Reply #1 on: 20 January 2016, 17:29:03 »
I suspect your battery is actually:
12v, 74Ah, with an 850A cranking capability.  Most car battery chargers should be fine.
« Reply #2 on: 20 January 2016, 17:32:25 »
Battery charger specs are designed to make you go and buy a bigger charger.
They all do the same job. A smaller one will take longer to charge a bigger battery and vice versa, but anything will do the job.
fcc-pt
  • Portugal
« Reply #3 on: 20 January 2016, 18:54:32 »
I wasn't sure but now I get it :D it makes sense apart from voltage 6/12/24 ...
So, I can think of a battery as a bucket. If larger then it takes more water, if the tap provides constant amount of water then it will fill a small bucket in less time then a larger one.
Thank you guys :D
« Last Edit: 20 January 2016, 18:56:32 by fcc-pt »
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 20 January 2016, 19:00:25 »
I'm just contemplating how you would fit an 850AH battery in to a miggy :P
fcc-pt
  • Portugal
« Reply #5 on: 20 January 2016, 19:13:12 »
Mine says:
74Amps and 850Amps per Hour :)
Ever Ready
  • Scotland
    • 2.2 CD Auto, Pug 308Hdi
« Reply #6 on: 20 January 2016, 19:27:44 »
Might manage to squeeze it into the boot ;D ;D
An ounce of experience is worth more than a pound of enthusiasm.
Keith ABS
  • Maldon Essex
« Reply #7 on: 20 January 2016, 20:52:35 »
  Not a problem if its an estate, loads of room ;D ;D
Keith ABS
« Reply #8 on: 20 January 2016, 20:55:33 »
Same way as in your milk float? ;)
fcc-pt
  • Portugal
« Reply #9 on: 20 January 2016, 21:30:05 »
I haven't made any changes it fits original :)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #10 on: 20 January 2016, 23:49:54 »
Stop pulling the OP's wire and tell him what the joke is!
Ron.
« Reply #11 on: 21 January 2016, 11:51:11 »
An 850Ah (Amp Hour) lead acid battery is roughly half a metre by half a metre by a quarter of a metre in size (google one up).
Car batteries are small in Ah capacity (e.g. 75Ah) and high in Cold Cranking Amps (e.g. 850CCA).
Just call me the joke killer.
