What code reader?
Started by tunnie, 25 January 2016, 18:41:42
Time for me to invest in a decent code reader, not after a mobile based one with a Bluetooth dongle.
Thinking something like this:
http://www.amazon.co.uk/Autel-Autolink-AL319-EOBD-Reader/dp/B007XE8C74/ref=sr_1_8?s=automotive&ie=UTF8&qid=1453747010&sr=1-8&keywords=obd2+scanners+2015
Recall this one having good reviews here previously?
Mr.OmegaMan
Bought one of these Autel Autolink AL519 last May/June does it's job just fine  :y
Ooo 519 that one is a 319. Googles....
Get one that displays live data. This will enable you to actually diagnose problems, rather than hope the fault codes are useful.
I don't find the Android/Bluetooth is any less reliable, but it is a lot slower to use.
pauls
I have the one in your link. Might not be the most advanced but it seems to cover codes from ecu and gearbox codes also live data. :y
Quote from: pauls on 25 January 2016, 19:07:05
Talking of which...
Quote from: Harris K Telemacher on 25 January 2016, 19:35:50
Talking of which...
Sounds good to me then  :)
For £28 not a big issue if no good - however these Autels not too bad
Be aware there are a lot of fake chinese Autel clones floating about .. if it is very cheap it is probably so for a reason .. that has nowt to do with luck ..... :)
I'd get it from Amazon on that link  :y :y
I have an Autel Maxiscan MS509, kindly given to me by a member here at OOF.
Seems to work pretty well although it has had a couple of 'computer says no' moments.
Fake or genuine I really can't tell.
YZ250
Quote from: Doctor Opti on 26 January 2016, 12:00:37
On some of the Autel's (MS509 being one of them, although no longer sold) you can tell a fake by going in to the settings, scroll down to Serial No. and if it has a number you may be ok, but if the serial number is made up of numbers/hashes/ asterisks etc it is fake.
My first MS509 was purchased from Amazon, from a seller that warned of fake Autel's, and carried a footnote to notify Autel if you came across a fake MS509.
The MS509 delivered to me by them was fake.  ::) ;D
If buying from Amazon just be careful and read the seller reviews first.  :y
Quote from: YZ250 on 26 January 2016, 14:44:24
I'm pretty sure my reader has such a number.
However, as the Omega is so reliable ::) ::) I haven't used it for a while, so could be wrong.
If its Amazon Market place, or "Supplied by XYZ, fulfilled by Amazon", its generally best to give it a wide berth in my (sadly far too extensive) experience.
