Water Temp Gauge sender
Started by Peterskinn, 27 January 2016, 11:30:11
Peterskinn
.....and another thing!
Following the CH gasket change and associated work the car has continued to run well and the heater is great (faster to warm up if anything than my Diesel Jag)
When I did the work I soldered the spade terminal onto the sender unit at the rear of the cylinder head. My thinking was that this would be simple way of ensuring an otherwise dodgy electrical connection. I then used a simple choc-block connector to make the connection to the original cable in the loom.
Initially worked fine and registered on the gauge as you would expect as the car warmed up and settled to its operating Temp. But soon.....  nothing! The needle doesn't move off the lower stop.
I've checked the connections - all OK -  and now suspect the sender unit which I would imagine is relatively easy to change?? I notice that the brass stud (to which I soldered the tab) can be rotated. Is that correct??
Anybody any other suggestions??
Quote from: Peterskinn on 27 January 2016, 11:30:11....
I'd say not.
'Earth' the blue wire that should go to the temp sensor & the gauge show go to HOT  :y
Peterskinn
Great - I'll try
Just as soon as it stops blowing a gale!!
Peterskinn
I'm confused now.....
I earthed out the temperature sender - no visible effect whatever.
Just to be clear - there are two "senders" one I understand is warning light and one sends to the temp gauge in the dashboard??
One has the little brass disc onto which a "Faston" tag from the wiring loom fits, the other has a small plastic plug.....
Which is which??
Pic of a 2.0 set up. 2.2 same but no dispack
Peterskinn
Ah Thanks - but I'd found this pic.
I'm still unclear from the pic which is which though............
My concern is that the gauge on the dashboard doesn't work at all.
In infer that this is the small brass item - so what does the item with the plastic plug do??
I just don't want to replace the wrong unit??
Tells the Engine management unit the Coolant temp so it can work out fuelling / air ratio etc.
Peterskinn
Ah Great Thanks!
So - if i replace the little brass widget ( £3.07) there's a half decent chance I'll have a temperature gauge?
Still strange that nothing happens when "earthed" though?
Quote from: Peterskinn on 19 February 2016, 16:15:06
ignition on ......  ::)
You did earth the wire and not the sensor... :-\
Peterskinn
I think for £3 or whatever I'll just buy one and see what happens........
I'll report back.
Thanks again to all!
Peterskinn
So - duly ordered a sensor and - eventually - got around to replacing it yesterday .......... No change.  :(
Is it likely that the gauge itself would just pack up?? Is there any wiring/plugs in the circuit that are worth a check??
andrew38
I have the 2.6 V6 same problem, mine packed up after a thermostat change, worked for a while then stopped. It does occasionally come off the bump stop but only when accelerating hard. I live with it as the cooling fans all work fine and the car runs great. I thought it may have been an airlock but then that would effect the ECU sensor beside it as well I would guess.
Garage did as you did, changed the brass sensor but no different, think they earthed it out and it was ok.
