Author Topic: wipers..... again.  (Read 8560 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
wipers..... again.
« on: 31 January 2016, 13:31:37 »
Wipers work and give a full sweep from top to bottom but when i turn them off they rest mid screen??? Relay fault??
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: wipers..... again.
« Reply #1 on: 31 January 2016, 13:38:41 »
Much more likely to be the park switch in the motor.
vauxsull
    • 3.0 Elite
« Reply #2 on: 31 January 2016, 14:01:49 »
Its a brand new motor changed it 3 weeks ago and all was well untill today???
« Reply #3 on: 31 January 2016, 14:12:30 »
Water ingress :-X
vauxsull
    • 3.0 Elite
« Reply #4 on: 31 January 2016, 14:13:57 »
If it was an old rusty unit possibly.. but its literally brand new.... is there another possible cause???
« Reply #5 on: 31 January 2016, 14:15:50 »
If the motor is new and the fault has returned, then clearly the motor is not the problem...
vauxsull
    • 3.0 Elite
« Reply #6 on: 31 January 2016, 14:17:43 »
The original motor was changed as it didnt move at all... new one fitted and happy days... untill today...
« Reply #7 on: 31 January 2016, 14:21:23 »
When the same thing happened to the new one... I would save some cash and get another second hand motor as you've likely bricked the new one too...
I would wager that it's shorting out in the plug or loom, either through wear or water ingress...
vauxsull
    • 3.0 Elite
« Reply #8 on: 31 January 2016, 14:23:54 »
Right then... im going to drown it in WD40 right now....
« Reply #9 on: 31 January 2016, 14:37:03 »
Might be prudent to check the loom first... might even be a switch fault, but loom most likely as you would have disturbed a section of it swapping the motor out :-\
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #10 on: 31 January 2016, 14:38:33 »
I've had this issue and it was the relay - yellow one in the engine bay box.
Does the wash/wipe behave ok?  To get mine to park properly, I had to use the windscreen washers.  I cleaned the contacts in the relay and it worked for a few weeks but the problem came back so I go a new relay.
vauxsull
    • 3.0 Elite
« Reply #11 on: 31 January 2016, 14:42:53 »
I shall try the relay now.. hamg loose and chat amongst yourselves .. be right back  :D
vauxsull
    • 3.0 Elite
« Reply #12 on: 31 January 2016, 14:49:56 »
Not the yellow relay..
« Reply #13 on: 31 January 2016, 14:58:09 »
Check the positioning as per this guide :
http://www.omegaowners.com/forum/index.php?topic=117001.0
« Reply #14 on: 31 January 2016, 14:59:01 »
confirm - park doesnt work on any wipper speed setting, or on wash wipe?
