Car Aerial
Started by EMD, 02 February 2016, 14:04:06
EMD
Can a better car aerial be fitted for boosting signals/receptions and if anyone has done so which one did you fit  :-\
Omegatitis
I've never had any issues with signal in either cars, unless you get one of those things which is about 5ft high can't see it making a massive difference  :-\
EMD
Signals around here seems to be poor or the aerial is just not good enough , the signal strength seems to be the problem as when im on the move the stations just keep going all fuzzy  >:( Ive checked all the connections right through to the ones under the parcel shelf so its not that  :(
When i used the Mazda's radio the reception was clear and crisp with no interference on the same radio stations so it has to be the aerial  :-\
Omegatitis
The whole back screen is the ariel, wonder if any cracks/gaps in the heated screen element affect the radio? Not to sure how it uses the screen.  :-\
EMD
Quote from: tunnie on 02 February 2016, 15:18:45
Whats that shark fin thing on the roof for ?  :-\
Omegatitis
Quote from: EMD on 02 February 2016, 15:20:41
GPS / telephone if you have either/both .. :)
EMD
#6
Quote from: Entwood on 02 February 2016, 15:22:04
Neither  ???
What i'm considering is disconnecting the aerial from the rear screen and routing an independent aerial either roof mounted or rear wing mounted .
Omegatitis
zirk
The rear screen Amp and Aerial dont do a bad job if Im honest, could be, bad earth on Amp, no volts to Amp, Cracks / Breaks in rear screen, does it get better or worse with the rear screen heater on / off.
EMD
Quote from: zirk on 02 February 2016, 16:37:54
Dont think ive ever tried the radio with the rear screen heater on . I will try it tomorrow morning . Suppose to be a sharp frost anyhoo ::)
Omegatitis
Aftermarket tat, if we are talking about Omegas.
Wipe the inside of the rear screen with a soft cloth as well.
EMD
#11
Quote from: TheBoy on 02 February 2016, 17:45:06
No no its standard , it screws into the roof ... i think its the same as the elite  :-\
Same as seen here :
Omegatitis
Well that ain't a shark fin then ;D
That's just a GSM aerial for cellular prewiring.
Keith ABS
  I have a new amp if required
Keith ABS
One pictured is bee sting one. That's GM, shark fin looks totally different  :y
Sure some came with it just because, my dads 2.2 came with it. Never has GPS or Phone, came like,that from factory!
Also depends on the base, if just a stick it's GSM only I think. If they have a fatter base, that means they do GPS.
Nothing to do with radio tunes  :y
