Author Topic: elm 327 software and Trouble Codes  (Read 3339 times)
jimjimanta
  • hellas
    • opel omega b , opel manta
« on: 04 February 2016, 15:01:20 »
i have this produkt :
http://www.ebay.com/itm/Mini-VGate-Scan-ELM327-Bluetooth-OBD2-V2-1-OBDII-Auto-Torque-Scanner-FHRG-/111305997630?hash=item19ea5abd3e:g:AfcAAOSw3xJVelKb&item=111305997630&vxp=mtr
I connect it to my car and took out lesions .
PO135
PO 325.
You must replace the lambda sensor and the knock sensor ?
and The lamp comes on  the airbags, but not reading this damage to be able to erase.
you have to propose a program for this device;
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: elm 327 software and Trouble Codes
« Reply #1 on: 04 February 2016, 15:23:57 »
What Car, model, engine, year.
    • E250 Est / Elroq
« Reply #2 on: 04 February 2016, 16:03:18 »
Never take a fault code to mean that component needs replacing (although sometimes that is true)
It is an indicator of a sensor reporting its seeing something not right.
Eg a lambda sensor may throw a code because the fueling is incorrect.  You need to work out where the problem is using codes as a guide.
jimjimanta
  • hellas
« Reply #3 on: 04 February 2016, 17:29:01 »
my car is opel omega caravan 2000 cc , 16v , 136 hp , year 1998 .
  • Auckland
    • Mazda MPV
« Reply #4 on: 04 February 2016, 18:03:49 »
Does anyone know if the Simtec 56 (2.0l) ECU suffers from the same brainfart as the Simtec 75 (2,2l) ECU when there is a problem with the camshaft (hall effect) sensor?
jimjimanta
  • hellas
« Reply #5 on: 06 February 2016, 14:57:09 »
what measurements must I make the lambda sensor, and knock sensor ,  to i check if he will change;
