Author Topic: Oh Poo  (Read 2705 times)
Sipey
  • Maidenhead
Oh Poo
« on: 16 July 2008, 21:04:04 »
Evening all,
Please could you tell me how to remove a security wheel nut that has had the teeth burred so the key no longer fits. I have been trying in vain for the past 2 hours.
I have soaked it in penetrating fluid, hit it, rocked it, heated and drilled it (now I have no drill bits left). Is there a tool for removing them?????
Cheers folks,
Mark
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Re: Oh Poo
« Reply #1 on: 16 July 2008, 21:06:13 »
Drill the alu cover in the side, then leaver the cap away with a chisel... i did this today! No good if you need to reuse though! I also tried 3 drill bits, but was a hex bolt in effing steel!!! :y
JiMbOb789
  • Timaru, New Zealand
    • x4 Omegas
Re: Oh Poo
« Reply #2 on: 16 July 2008, 21:06:36 »
someone has done this on here before, i think there may be a tool, i cant remember what it was called, someone will come along and tell you now mate :y
70spider
  • Ipswich
Re: Oh Poo
« Reply #3 on: 16 July 2008, 21:09:44 »
yes mate had this screw driver and hammer just tap round quite a short thread
Re: Oh Poo
« Reply #4 on: 16 July 2008, 21:14:24 »
If they're the Vauxhall ones with the ring around the outside, they are a pain to get off. I paid about £30 in drill bits and then had to use a chisel and mallet to finish the job off :(
« Last Edit: 16 July 2008, 21:14:48 by Elite_Pete »
Sipey
  • Maidenhead
Re: Oh Poo
« Reply #5 on: 16 July 2008, 21:29:41 »
They're the one's pete. Have gone through a whole set of Bosch drill bits so far and no where near to getting the b$@%@%&@ off
psychnurse
Re: Oh Poo
« Reply #6 on: 16 July 2008, 21:31:34 »
Just give them some muscle  :y ;D
psychnurse
Re: Oh Poo
« Reply #8 on: 16 July 2008, 21:39:30 »
http://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set-expansion-set/path/socket-sets-sockets-tool-sets
 :y :y
Or that would be the diplomatic way out... that I should have taken  :-/
Phil
Re: Oh Poo
« Reply #9 on: 17 July 2008, 08:56:32 »
 :y :y
These DO NOT work on the VXL nuts as the large outer ring just spins.
You can buy the professional set the AA use but its £150 odd plus the VAT, best to pop down a tyre place as they normally have the kit and charge about £30 to remove the set, BUT they cannot be re-used after
Re: Oh Poo
« Reply #10 on: 17 July 2008, 09:31:17 »
 :y :y
The local ATS used something more like these :- clicky that have a finer helix. The locking nuts they took off were Vauxhall's 3 prong type, but they took spinning collar in their stride!   :y How good they would be with e later 'cake cutter' type I'm noot sure, as the spinning collar is more substantial.
And they didn't charge me either!  ;)
« Last Edit: 17 July 2008, 09:31:53 by Andy_B »
Phil
Re: Oh Poo
« Reply #11 on: 17 July 2008, 11:56:54 »
They do not work on the 'flower/ cake cutter' type, as you said the outer collar is more substantial which means it does not grip.
The set i was talking about was this:-
Professional locking nut remover
Not cheap but works every time
Re: Oh Poo
« Reply #12 on: 17 July 2008, 12:05:13 »
Ah! I see!
They're obviously secretive about exactly how it works.
Sipey
  • Maidenhead
Re: Oh Poo
« Reply #13 on: 18 July 2008, 21:55:34 »
Got the bloody thing off  :)
Took it to Kwik fit and got them to remove it  :y
Got it MOT'd today as well. Failed on indicator bulbs being incorrect colour and excessive play in wheel due to knackered track rod end - they changed them for me and all is good. :y
« Last Edit: 18 July 2008, 21:56:49 by JOZE4 »
FRE07962128
Re: Oh Poo
« Reply #14 on: 18 July 2008, 21:57:54 »
Oh yes Kwik Fittup are good at destroying things! ;D ;D ;D ;D ;)
