90 degree
Started by raywilb, 15 February 2016, 19:27:20
raywilb
I rang 4 motor factors & evans halshaw today just trying to buy those rubber inserts + 90 degree bends attached to the vacuum pipes. nobody stocked them. surprised the stealers said they had none in stock. surely the service bay at times need  one.
BazaJT
Could be that they're on back order at the stealers?Other than that I'd have a wander round a local breakers yard,should be such things on other Vx models or I should imagine on quite a few other makes/models.
flyer 0712
I was in our local..A1 motor factors shop the other week and they had them for sale in there... :y
Quote from: flyer 0712 on 16 February 2016, 20:58:47
Any motor factor should have them. You will have to ask.
Quote from: Nick W on 16 February 2016, 21:11:18
Nah, not round these parts. ECP, GSF, mazumammawhatever, Hellfrauds, all failed.
If all else fails and you desperately need some, Halfords do a thick walled rubber vacuum pipe that will slide over the hard plastic pipes in the same way. Obviously you can't achieve the same tight bend radius but it can get you out of a hole (literally) if needed.
