Cadillac seville sts northstar V8
Started by 78bex, 16 February 2016, 01:14:33
EMD
Quote'service suspension system'
Thats one message that the omega dont disply  ;D
Its a kind of quirky car but cheap way to get into the v8 world if you got it a lot cheaper than asking price , fwd   :(
Omegatitis
Broomies Mate
They all suffer with that suspension problem, sadly.  Not a cheap fix either, however, it doesn't really affect the ride.
The V8 sounds quite nice, considering it's small capacity.  Not very rapid, though.
2boxerdogs
Probably get it for a grand, worth a punt.
Been on here before that has, it would appear no one is biting. I, personally, never trust anyone that turns a car around that quickly.
omega2018
sold for £841 last november, 10 bidders.  seems none of them actually wanted it hence seller resubmitted it, twice, at £1,400 then again at £1,300!
biggriffin
Quote from: Tilbo on 16 February 2016, 15:37:14
Then rip out the engine and drop it in webbys for his 0-60 quest ;D
Hoof'land storeman.
2boxerdogs
Quote from: biggriffin on 17 February 2016, 10:30:21
Sounds like a plan..😀 😀 😀
Quote from: Tilbo on 17 February 2016, 11:09:51
Seems like a
lot of work to only get 300bhp. And what gearbox do you suggest considering the Seville is FWD?
Quote from: Nick W on 17 February 2016, 22:10:34
Seems like a
An AF40 :D
2boxerdogs
Seems like a
Wouldn't have the foggiest idea, not mechanically minded 😀 😀 😀
And what gearbox do you suggest considering the Seville is FWD?[/font]
Anything you can fit to the GM small metric pattern (with a slight tweak) ;) I'm sure there'll be bell housings & adapters available on the other side of the pond..
..that said, it would still be easier to drop an LSx into something as that would all be off-the-shelf.
Yuk! Kill it with fire. ;)
Engine is way too wide to fit in an Omega anyway, well, if you want exhausts, at any rate.
EMD
Can have exhaust exiting the front wings  ;D
Omegatitis
Quote from: EMD on 19 February 2016, 12:47:27
You can, but good luck getting the pipes there ::)
