Author Topic: Opel, Vx Satnav Series HU's and Speed Camera Alerts  (Read 7984 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 16 February 2016, 18:30:19 »
This is probably a load of old Bollards but was having a chat with someone who's a Parts / Service Manager for one of the Nissan Dealers, some how we got on the subject of SatNavs, and he mentioned certain Map Disks for Nissan are compatible with Opel / Vx HU's and have the added benefit of being able to add UK Speed Camera Data?, any one come across this???
I'm kinda of guessing later NCDC units rather than the older Carin?
« Last Edit: 16 February 2016, 18:39:59 by iZirk »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Opel, Vx Satnav Series HU's and Speed Camera Alerts
« Reply #1 on: 17 February 2016, 10:05:54 »
Can`t see it myself  :-\
In the olden days, when CARIN was about, quite a few other marques also fitted it too, so there may be some merit in that
But you are talking of a system that has been obsolete for near 15 years now  ::)
Radio & Decoding Technician
www.dndservices.co.uk
zirk
  • Epping Forest
« Reply #2 on: 17 February 2016, 16:51:33 »
My thoughts exactly, gut feeling is he may be a bit miss informed, although he's been with Nissan a few years now.
Thought I'd post up just in case we were missing a trick.
He may be able to get me a disk, over stock levels allowing, which could be interesting as half the Vx HU's these days wont even read a proper Vx one.  ;D
    • 530D M Sport, 330i Coupe
« Reply #3 on: 17 February 2016, 18:15:17 »
Would be interesting to compare the file structure - folders, contents etc.
I've previously wondered if you could copy later compatible mapping data (Navteq for NCDx) into the correct location on a imaged version of the last (2011) map disc. I'm sure it's not that simple though!
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 17 February 2016, 18:28:22 »
The number of computer nerds people,that haunt this forum,i'am sure the answer is out there :P
Hoof'land storeman.
zirk
  • Epping Forest
« Reply #5 on: 17 February 2016, 18:29:57 »
The Speed Camera is just a database end of the day, anything from a CSV file upwards, a few years back when Nokia Maps stopped doing the Camera Base due to the French rules, I managed to copy a n other (Tom Tom I think) into the correct Directory and replaced a blank file with some success and got it working.
« Reply #6 on: 17 February 2016, 18:37:12 »
Yep, I've used various free apps to convert POI files from one format to another with variable success.  :y
It's the updated maps that are of primary interest to me.
zirk
  • Epping Forest
« Reply #7 on: 17 February 2016, 18:53:40 »
Yea, that could be a bit more challenging, Nokia Maps, now called Here Maps has, as far as I know, taken over Navtech Maps, so there could be some new issues that are backward compatible across various ranges.
website Here -  http://www.navigation.com/is-bin/INTERSHOP.enfinity/WFS/Navteq-NavteqEurope-Site/-/-/-/Default-Start
Online Here Nav - https://maps.here.com
« Last Edit: 17 February 2016, 19:11:17 by iZirk »
« Reply #8 on: 17 February 2016, 19:17:46 »
More likely to be the "newer" 10yr old systems that the NCDC.  The software for the NCDC is on the actual map disk (ignoring the bollards that Navteq claim - they are completely wrong), and hasn't been updated since about 2005.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 18 February 2016, 09:58:08 »
In the early nineties, most Sat-Navs were standalone systems and it wouldn`t surprise me if software could be swapped as a Vauxhall CARIN, a Nissan CARIN and and aftermarket CARIN are pretty much the same unit - all displaying the Philips Logo and branding. I know that the replacement for the CARIN (when Philips became VDO DAYTON) did not use any backwards compatible software at the time and was heavily encrypted back then.
The "proper" sat navs that are integrated into the vehicle (ie high speed units for cars, as opposed to the cheap portable devices for hikers and bikers) all generally have some form of "update" on the disc for the operating system of the vehicle they are fitted to. Whilst there are very few Map/Software/Data providers that produce these discs, (usually Teleatlas or Navtech) and you may think that there should be some compatibilities there, don`t also forget that security software has also moved forwards leaps and bounds to prevent discs from being swapped as you are hoping. That said - if your can break the file structure to insert a later database - who knows?
I also have a deep suspicion (for the conspiricy theorists amongst you) that one of the reputable mapping providers for the VAG group has actually put a dodgy version online, where the download would corrupt the bios of the unit when loaded, with the underlying message of "stop using pirated software" and whilst we cannot prove this, we do see a good dozen Audi / VW Nav units here each week for the same problem !! Whoever wrote the software really knew what they were doing, as it also turns off the eject mech, so the counterfeit disc remains inside the unit.
Hmmm . . . .
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #10 on: 18 February 2016, 19:35:04 »
OOOH,a conspiracy theory :D Much loved on here they are ;D ;D
« Reply #11 on: 18 February 2016, 19:58:49 »
I'd heard something similar regarding the VAG units as well. Also heard of a few people using VAG-COM to upgrade the flash card versions and ending up trashing the maps and the language defaulting back to German  ;D
« Reply #12 on: 20 February 2016, 10:12:20 »
Vor you, tommy, ze vor iz over
biggriffin
« Reply #13 on: 20 February 2016, 16:35:18 »
 £169.00 +£5.00 postage. Cheaper to buy a new standalone unit. :-X
Hoof'land storeman.
« Reply #14 on: 20 February 2016, 23:36:45 »
But a cheaper stand alone unit will always be inferior to the built in one.  ;)
Says the man who generally uses TomTom on his phone :-X ::) Unless going into a heavily built up area, in which case the one in the car runs along side, just in case ;)
