2.2 dti ?
Started by raywilb, 24 February 2016, 20:53:52
raywilb
any body with a dti will you be able to tell me if the egr valve points with the pipe pointing towards the front of their car. I cannot find any thing on line. basically I,m not sure if tubes from solenoid are right,
No, EGR pipe connection points to the back
raywilb
Quote from: VXL V6 on 25 February 2016, 19:55:31
as I thought, reason I asked is if I,m stood at n/s wing looking at the solenoid the vac pipe to egr valve is coming from solenoid on the right where as from the vac pump on the left, hence the two pipes are crossed & that just doesn,t look right :-\
