Thank you epoxy
Started by EMD, 27 February 2016, 13:37:34
EMD
Broke the sun roof plastic motor surround as i mis read that it just pulls off  :-[ :-[ The little black clip snapped and the plastic groove bent back and cracked  :( Out with the epoxy and its all back together  :D Always a good idea to have some handy i say for those little moments when things break  :-X
Omegatitis
Quote from: EMD on 27 February 2016, 13:37:34
Broke the sun roof plastic motor surround as i mis read that it just pulls off  :-[ :-[ The little black clip snapped and the plastic groove bent back and cracked  :( Out with the epoxy and its all back together  :D Always a good idea to have some handy if you're as kak handed as me!  :-X
Fixed!  ;)  ;D
EMD
Quote from: Sir Tigger on 27 February 2016, 13:41:12
Fixed!  ;)  ;D
And that  :D Its a horrible sound when something snaps  :-[
Omegatitis
I know that sound well Mr EMD, and you just get that sinking feeling....  :(
Pretty ham fisted myself and my favourite trick is over tightening things until they break or go round and round!  ::)
Bigron
Only slightly related, but I hope of help; I came across these devices for woodworking when browsing at a boot fair. They are called "inserts" and are great for when you wear out the screwholes in wood. Drill a slightly oversized hole and then screw the coarse-threaded steel insert into the hole - it has an Allen socket at its centre. Also down the centre is a thread for a machine screw to replace the original wood screw.
Screwfix used to carry them, but I cannot find them in their current catalogue - maybe ebay?
Ron.
Rivnuts and the insertion tool are another get-you-out-of-trouble gismo. Especially if you hate self-tapping screws into sheetmetal.
Available from any industrial fastener supplier for pennies.
Mr.OmegaMan
Quote from: Sir Tigger on 27 February 2016, 13:57:53
Did this with the plenum bolt on the front right side that holds a bracket last year.. Nothing overly important nevertheless I was really annoyed at myself for that. Was only meant to be a quick job to get access to something ::) ;D
Bigron
Nick, are those Rivnuts also know as hank bushes, because if so I've used them in the past and they are brilliant!
Ron.
