How to ??
Started by LFF64, 01 March 2016, 12:10:46
LFF64
Would anyone have access to Vauxhall drawings manual for the insignia ?
I can look on  epc for parts but what I want to know is how to fit the Bracket for the load compartment net 23 51 060 / 062
What I am looking for is any instruction or drawing as to the position that it is fitted
Quote from: LFF64 on 01 March 2016, 12:10:46
The proper kit comes with a template...
LFF64
Guess I will have to do it the hard way then remove the grab handles and try to get fingers under the headlining to find the hole
Quote from: LFF64 on 06 March 2016, 08:34:22
Do Vauxhall not do a fitting kit then?
It's not a simple hole either, and the hole required in the headlining doesn't match the mounting point in the structure. Don't forget, there's also the lower mounting to consider.
All of this, plus the template, will be in the kit ;)
http://www.ebay.co.uk/itm/VAUXHALL-INSIGNIA-ESTATE-LOAD-COMPARTMENT-NET-BRACKET-LEFT-GENUINE-13222444-/321837622456?hash=item4aef0464b8:g:HvEAAOSwgQ9V1Jmb
http://www.ebay.co.uk/itm/VAUXHALL-INSIGNIA-ESTATE-LOAD-COMPARTMENT-NET-BRACKET-RIGHT-GENUINE-13222445-/321784392897?hash=item4aebd82cc1:g:ceQAAOSwrklVgED9
http://www.ebay.co.uk/itm/VAUXHALL-INSIGNIA-ESTATE-2-ROW-SAFETY-NET-BRACKET-COVER-RH-GENUINE-13293377-/321790940764?hash=item4aec3c165c:g:JsYAAOSwu4BVirND
LFF64
How much  :D
It would be cheaper to stick the dogs in kennels
Thank you for taking the time to look I couldn't find anything like that anywhere
Quote from: LFF64 on 06 March 2016, 17:31:53
How much  :D
It's a factory option, and the kit is what the factory use ;) next time, order it with the car :D
