Author Topic: mot advisories  (Read 1658 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
mot advisories
« on: 04 March 2016, 12:47:54 »
please can anybody explain what this means, & how to rectify.. "Supplementary Restraint System warning lamp does not illuminate." one of last years advisories. others were two brake pipes, done those.
  • Auckland
    • Mazda MPV
Re: mot advisories
« Reply #1 on: 04 March 2016, 13:42:51 »
I assume that will be commonly known as the 'airbag warning light'.
First thing to do is pop the instrument cluster out and check that it hasn't been removed to hide a fault.
Re: mot advisories
« Reply #2 on: 05 March 2016, 00:03:49 »
Yep sounds like the warning lamp bulb has been removed or has failed.  Easy enough job to get instrument cluster out to check/fit new bulb (10 mins at most) - there's a howto on here.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: mot advisories
« Reply #3 on: 05 March 2016, 11:43:58 »
I thought that non illumination of air bag light was now a failure. :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: mot advisories
« Reply #4 on: 05 March 2016, 11:51:25 »
They put it on hold a couple of years back, so guessing its still on hold, or up to the Tester.  :-\
