Author Topic: Gear Selector Lock Solenoid Part Number  (Read 2663 times)
MG
  • Worcester Park
    • 1999 Elite Estate 2.5 V6
« on: 05 March 2016, 17:48:37 »
Hi
The solenoid that unlocks the gear selector when in park has failed on my 1998 V6 Elite.
I need to try and source a replacement.
Can anybody help with part number and where I may be able to obtain one?
Many thanks guys.
Mel.
Mel.
shyboy
  • Southport, merseyside.
    • Mazda 6
Re: Gear Selector Lock Solenoid Part Number
« Reply #1 on: 05 March 2016, 18:37:36 »
Unless you have proved it's the solenoid beyond doubt, check the brake light switch/switches first.
I've just solved the problem on a Corsa 'D', and found that the brake pedal unit has two switches, one for the brakelights and a separate one for the gear lever locking system. So brakelights can still work normally although gear solenoid won't. I presume the Omega works the same way.
« Reply #2 on: 05 March 2016, 20:28:42 »
Not sure it's as simple as you say  :-\, but a duff brake light switch will give the same symptoms ie you can't get it out of Park .... been there at traffic lights stuck in Park struggling to go!  ;D
MG
  • Worcester Park
« Reply #3 on: 05 March 2016, 21:07:51 »
Yes I have taken the solenoid off the car and applied 12V and it is dead!
Does anyone know where I can buy a replacement or obtain part number?
Thanks guys.
Mel.
