Car alarm needed for the lads corsa c
Started by tigers_gonads, 10 March 2016, 13:06:30
tigers_gonads
As above really  ;D
Looking for a aftermarket kit which will make a noise and work off the central door locking system so getting rid of the need to have a extra remote dangling off the lads key ring  :y
I want something that will be pretty reliable too so not looking for something from poundland, 99 pence shop ect  :D
I used to fit a hell of a lot of these things in years gone bye before those bastids at Thatcham decided to nick all my customers back around 92 ish by making the manufactures install them at the factory so fitting will not be a problem  ;)
TIA  :)
zirk
tigers_gonads
Quote from: STEMO on 10 March 2016, 14:39:52
Quote from: Zirk on 10 March 2016, 14:10:44
There you go, 54p
Just remember your Anodes from your Cathodes, or put in another way youve got a 50/50 chance of wiring it in correctly
http://uk.farnell.com/kingbright/l-56bhd/led-blinking-5mm-bright-red/dp/1142543?CMP=KNC-GUK-FUK-GEN-SHOPPING-KINGBRIGHT&CAGPSPN=pla&gross_price=true&gclid=CIX1zqmltssCFfUV0wodRMYPYA&mckv=HO3lRWzi_dc|pcrid|78108292869|&CAWELAID=120173390000010511
Enough to make most thieves move on to the next available motor  :D
Too true that  ;D
The thing is, he is looking to rebuild the sound system in it so needs something that makes a noise  :)
I know that sigma used to make a cat 2 upgrade for cars with separate central locking and cat 1 immobiliser (via keyfob chip)   Worked / armed off the central locking relay pulse  :-\
Think it was classed as Cat 2a for insurance purposes  :-\
tigers_gonads
tigers_gonads
Quote from: Harris K Telemacher on 10 March 2016, 16:45:10
Does it not have a factory one :-\
Nah sadly  :(
Started off as a basic  "life" model but since been spec'd up with much better interior  :)
biggriffin
By a cheap, siren, and wire it into door switch circuit, fit hidden on off switch, Door open siren go off, "old skool" simplicity  :)
Hoof'land storeman.
