Author Topic: The place of the speaker of parking pilot ?  (Read 2900 times)
Okan ÖZKAN
  • TURKEY
    • Omega 2.6V6 Elegance
« on: 12 March 2016, 11:43:50 »
The sensors work fine I can hear the signals of all four sensors from outside of the car but there is no sound in the car even I select reverse gear . There is no starting BEEEP sound . I guess the speaker is broken that's why I need to learn that where its located .  ??? ???
Re: The place of the speaker of parking pilot ?
« Reply #1 on: 12 March 2016, 15:26:34 »
Left hand headlining about fifteen centimetres in frm the B post... Bit further back if sunroof equipped.
Assume the speaker is dead, and fit a tweeter from the front door... Place this up above the lefthand rear wheelarch behind the boot lining :y
Okan ÖZKAN
  • TURKEY
« Reply #2 on: 12 March 2016, 15:37:27 »
Hmmm I guess I couldnt understand the location exactly  :-[
How can I reach that location where should I start :)
« Reply #3 on: 12 March 2016, 15:45:06 »
Ecu is located.behind the left hand boot trim. Look for a pair of wires dissappearing up the C pillar... These go to the speaker, which is roughly above the head of the rear left passenger.
As you have already established that the speaker is no longer working, check it is still plugged in, if so it needs replacing. If unplugged, plug  it in and see what happens. If everything else looks connected and still not working, then you can cut the original speaker wires and connect another speaker to them... A small speaker/tweater from the front door is perfect for this job ;)
Okan ÖZKAN
  • TURKEY
« Reply #4 on: 12 March 2016, 16:29:35 »
If the cables are correct in the picture , I am going to try to connect a twitter and try my speaker is broken or not . They are going to inside of the car . I opened the cover a bit there are two cable .
http://oi64.tinypic.com/smt0xs.jpg
« Last Edit: 12 March 2016, 16:37:24 by Okan ÖZKAN »
Okan ÖZKAN
  • TURKEY
« Reply #5 on: 12 March 2016, 17:14:53 »
Yess correct cables . I connect a speaker now it works. but sound is thinner I think I need to learn the original speaker specs and buy a new speaker .
« Reply #6 on: 12 March 2016, 17:25:32 »
Job jobbed :y
At least you now know what's what with it and that the rest of the system works :y
Okan ÖZKAN
  • TURKEY
« Reply #7 on: 12 March 2016, 17:50:09 »
Yes thanks a lot for your helps  ;) :y
