fld vision low beam
Started by raywilb, 12 March 2016, 18:34:27
raywilb
when I first drove my mig the fld vision warning was displayed & thanks to oof I found out about the sensor, so was able to rectify it. a couple of days ago warning appeared again, so I thought easy fix. however yesterday & today the warning is not on. Gremlins or what.  ???
powerslinky
Quote from: raywilb on 12 March 2016, 18:34:27
There are 2  . . .   but wait until / if  it returns  & check out both sensors . Usually just the connecting arm popped off  . . .but that would not correct itself  :-\
Possdibly the rear sensor if the car was loaded differently when the warning came on :-\
Identical to the front sensor, and also on the lefthandside :y
When it does it, drive up to a wall with headlights on, and see if they are both same height.
If 1 is low, it could be servo failure. Both low, likely to be sensor related.
