Wanted: 2.5TD Boost Pipe.
Started by P6UL K, 14 March 2016, 01:31:08
P6UL K
I'm after the solid boost pipe that runs from the turbo to the intercooler.
TIA  :y
zirk
Quote from: P6UL K on 14 March 2016, 01:31:08
TIA  :y
Are the ones fitted to the BM's not the same, or be made to fit, might expanded your search somewhat.
Quote from: Zirk on 14 March 2016, 11:04:48
TIA  :y
Unlikely, as intercooler is unlikely to be in exactly the same place, given the body differences in the car...
I'd probably suggest buying new, as a 14yr old intercooler host is liable to have some give in it now, wasting precious boost.
P6UL K
Quote from: TheBoy on 14 March 2016, 11:38:41
FYI... It's a solid pipe
Quote from: P6UL K on 14 March 2016, 11:57:16
OK, that's different from other Omega 2.5TD's I've seen then, which all use, by necessity, a flexible pipe (as the intercooler is mounted to the body, which means moves in relation to the engine).
Unless we're at cross purposes?
P6UL K
Part number of the pipe i need is: 905 73306  :y
