Leaking mixer tap
Started by EMD, 14 March 2016, 14:29:19
Magwheels
Gravity from loft tank pushes the water out of the "immersion" tank. The pump is probably for the central heating, I take it it's not a combi boiler. Taps have different internals for low pressure (ie tank fed) and mains pressure. If you get the wrong one/ones then a very slow fill rate is all you will get. Some is true for cistern refills (ballcock in old money).
Terbs
Right....good explanations. Thanks chaps. Just shows how we just accept things. I will now do some checking. I reckon it will be new taps .....or grin and bear it. :(
