Author Topic: NCDC 2013  (Read 7097 times)
amba
  • Medway towns
    • German V6
NCDC 2013
« on: 19 March 2016, 17:55:48 »
Had new laser fitted last year and nav has behave pefectly since then,although in truth very rarely gets used but disc has always been in machine.
Today I pulled of motorway slip road and whilst listeneing to radio suddenly entire head unit shut down.Nav disc ejected .
Pushed on/off button and radio and head unit fired back up and has worked faultless since but nav will refuse to accept disc as everytime inserted it ejects .Have cleaned disc although it was spotless and is a genuine 2008/9 navtec disc.
Any ideas as would of hope new laser would of lasted more than 8 months given that it hasnt been used for more than 5 hours max intotal in that time.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: NCDC 2013
« Reply #1 on: 19 March 2016, 17:59:01 »
Will it accept and play a Music Disc?
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #2 on: 19 March 2016, 18:26:36 »
Havent tried that as yet Chris.
Will report back later ,thanks :y
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #3 on: 19 March 2016, 19:03:57 »
Well as advised have tried a music disc.....and it plays  :y...so assume something up with nav disc ??..
zirk
  • Epping Forest
Re: NCDC 2013
« Reply #4 on: 19 March 2016, 19:07:34 »
When you cleaned it Andy, did you clean both sides?, is it slightly warped at all.
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #5 on: 19 March 2016, 19:10:40 »
Gave it a good spray with CD/DVD lense cleaner fluid then polished with glasses cloth.
Disc looked to be totally flat and was spotless with no scratches on surface....although I adnit to only cleaning the written side....should I give the yellow label side a clean too ;)
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #6 on: 19 March 2016, 20:01:08 »
Both sides of nav disc cleaned,and I have checked and disc is totally flat with no marks/scratches etc.
Disc gets drawn into slot by motor,few seconds later disc is rejected.Just tried another music disc and it retains it and plays just short section of music so assume lens is recognising disc...any advise guys.
Might try disconnecting battery for hour or so and seeing if that helps ..
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #8 on: 19 March 2016, 20:05:35 »
That wont fit in the slot  ;D
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #9 on: 20 March 2016, 13:19:56 »
Just to be sure I tried another audio disc in head unit this morning expecting it to play.
No such luck though
Audio disc stuck in nav slot now .Wont eject or play so something is bust
Any ideas
zirk
  • Epping Forest
Re: NCDC 2013
« Reply #10 on: 20 March 2016, 13:43:56 »
No such luck though
Any ideas
Hmm, not sure, but I think if it was me be tempted to pull the power lead out of the back of the HU for a few hours and start again.  :-\
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC 2013
« Reply #11 on: 22 March 2016, 10:12:02 »
Sounds like a generic audio laser has probably been fitted, and not the correct type for reading the smaller data bits on the nav discs and has now failed.
Common mistake these days as the proper lasers are getting hard to find, and the inferior audio ones look almost identical and are readily available
Radio & Decoding Technician
www.dndservices.co.uk
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #12 on: 22 March 2016, 10:29:37 »
Thats not great,Dave,but thanks for possible reason...strange as it worked perfectly when I occasionally used it over the past 9 or so months.
Audio disc now stuck and wont eject so looks like thats the way it will need to stay unless anybody has any solutions for repairs to be done correctly .? :(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC 2013
« Reply #13 on: 23 March 2016, 09:48:16 »
Audio Lasers were never designed to play the Navigation data discs, as unlike audio tracks, they much smaller pits and troughs to record the data, and although you may initially get away with playing these, the laser will struggle to focus and burn itself out fairly quickly. Imagine how knackered your eyesight would be if you constantly had to squint at something that you couldn't quite see clearly.
Disc now stuck as unit cannot see anything in there due to failed laser, and therefore it does not know it has anything in there to eject.
amba
  • Medway towns
    • German V6
Re: NCDC 2013
« Reply #14 on: 23 March 2016, 15:58:49 »
Dave.
Is the fitting of the "correct" laser a proceedure you undertake as a service ? :y
