Author Topic: Fuel tank  (Read 1874 times)
gbh
  • forest of dean
    • omega cdx 2.6
Fuel tank
« on: 21 March 2016, 21:03:33 »
Was towing the new car back on trailer when big bang and the back box blew up,decided to keep going mineful of the petrol tank but with all the fibres hanging out thought it might be ok.Well checked today after cutting back box off,nothing left inside only fibres but the petrol tank seems to have expanded on its seam,quite wide in fact.Does anyone know if they are double skinned or is it just safer to get a new tank?Thanks Glenn
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Fuel tank
« Reply #1 on: 21 March 2016, 21:11:28 »
I wouldn't take any chances  ;)
Stick a request in the parts section and change it  :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Citroen C1.
Re: Fuel tank
« Reply #2 on: 21 March 2016, 23:18:03 »
Fuel tanks aren't double skinned. They are thick (around 5mm ?) plastic. I would get one from a breaker.  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Fuel tank
« Reply #3 on: 22 March 2016, 10:04:38 »
Are you sure you're looking at the fuel tank? And what happened to the heat shield around the exhaust?
gbh
  • forest of dean
    • omega cdx 2.6
Re: Fuel tank
« Reply #4 on: 22 March 2016, 10:57:35 »
The back box split open and yesterday i took the heat shield off.Under it the tank has a seam around its middle,the seam has widened to almost an 1.5 cm and at one point you can poke your little finger in about 1cm. The plastic is still there and no petrol appears to be coming out but it looks like another tank needed!!
Re: Fuel tank
« Reply #5 on: 22 March 2016, 16:30:39 »
Dodged a bullet there :o
