Author Topic: Easiest way to get small cable from dash to engine bay  (Read 6739 times)
Re: Easiest way to get small cable from dash to engine bay
« Reply #15 on: 30 March 2016, 09:05:50 »
Also wondering if there's any scope in feeding it through by the heater pipes? Might be possible to drill a small hole through the plate that the pipes pass through?
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #16 on: 30 March 2016, 12:13:41 »
if you remove the pedal cover thingy on the drivers side and look up you should be able to get it through the grommet that the heater vac pipe to hbv goes through.
John.
« Reply #17 on: 30 March 2016, 16:55:32 »
You could always do a Tunnie ie Senator and lakes meet ::) ;D ;D
« Reply #18 on: 30 March 2016, 16:58:48 »
Drill a hole through the screen... ::)
« Reply #19 on: 30 March 2016, 17:12:05 »
Not that technical ;) ;D
« Reply #20 on: 30 March 2016, 17:54:10 »
Wire installed. Went in alongside the LPG wiring, by the heater pipes.
« Reply #21 on: 30 March 2016, 17:58:19 »
You didn't fancy doing a Tunnie then :-\
