Key Programming
Started by LC0112G, 01 April 2016, 22:00:15
LC0112G
What's the crack with this/ My dealer seems incompetent.
Went in 3 weeks ago - my 3 button key fob locks and opens the boot 100% reliably, but the door unlock is extremely flakey. Sometimes I have to open with the key, which then sets the alarm off till I start the car. I assume the open switch in the fob is dickey. So I go in to order a replacement key.
They want V5 log book, passport, drivers license and inside leg measurement. I think they were surprised when I said yep - got all that in the car. Next they want the cars key-pass, which sadly I don't have. So £22 to re-order, and then I' booked in a week later for a re-programming.
A week later I pitch up, and the key hasn't arrived - it's on special order from Germany. So re-book for a week later which was today.
Pitch up today and leave the car with them for an hour, Go back, and they're saying the key won't program to the car. They're re-ordering another key incase it's faulty, but suspect it's the car, and want me to book it in for an hour's investigation - presumably at £100+ an hour. break that.
So - what's involved in programming a new key? - 3.0 FL Elite auto saloon on a Y plate? I've got a Tech 1 - can I do it with that? The immobiliser chip is fine - it's just the radio controlled central (un)-locking that's iffey.
When I bought a new remote from a local locksmith I was there for less than 15minutes on a Saturday morning. Drove up, he got the part from stock and the tech2, I gave him the car pass and my spare remote and he programmed both. Cost about £65 2 years ago. The woman after me paid another £20 because she didn't have the car pass. They will also supply and cut a key to code while you wait.
This is an everyday procedure if you use the right people. That is rarely a dealer.
LC0112G
Quote from: Nick W on 02 April 2016, 01:25:50
Yes - that's what I was expecting from the dealer. The one I use is usually Ok, but on this occasion....
What I don't get is - I have a working blade and transponder in the old key. Can I just remove the non working button unit and replace it with something like this :
http://www.ebay.co.uk/itm/Vauxhall-Omega-3-Button-anti-theft-Megamos-T-AM-2001-2004-car-key-remote-fob-/291671101581?hash=item43e8f3d08d:g:UmwAAOSwoydWqKOm
Then re-sync by pressing the ignition in and open/close buttons. Or does the fob itself need programming too?
I think a new fob needs to be programmed into the ECU before you can sync it :-\
The synchronisation is required because the fob needs to send a different code every time to prevent a thief with a scanner capturing a code  and playing it back to unlock the car later.
Bet they ordered wrong fob.  Happy to look anytime, either Brackley in eve/weekend, or Bletchley at weekday lunch
Assuming you have carpass
minifreek
Only need Car-Pass for immobiliser or any other ECU programming...
Usually with the fob, as long as you have the correct frequency transmitted to the CL ECU then it should just be a case of programming to the car via ignition and 10 secs....
Could also be that the fob just needs repairing/soldering....
D.I.L.L.I.G.A.F...
Quote from: minifreek on 05 April 2016, 16:19:04
Incorrect.
LC0112G
Well - I have a car pass now - arrived in the post over the weekend. Whether or not it's the correct car pass is quite another matter.
The car is booked in for another go at programming a new key a week on Saturday. If they can't do it then, then I'll tell them what I think of them  ::)
I'm quite surprised at the complexity of this programming. I don't understand why there are two programming's needed - one for the transponder, and another for the remote. If I were setting it up I'd allow the remote to be programmed in car providing a valid transponder signal was present in the ignition.
Quote from: LC0112G on 05 April 2016, 21:15:22
The transponder and the fob are totally unconnected (until you clip them together).
LC0112G
Quote from: Andy H on 05 April 2016, 21:36:28
Yes - I understand that the transponder needs programming to the car (though I'm unsure if it's to the immobiliser or ECU). But - once you've done that and got a valid, programmed and recognised transponder in the ignition and the ignition turned on then the CL fob ought to be able to be synced without requiring Tech 2. After all, you've got enough there to open the car (with the key), start the car and drive it away regardless of remote C/L FOB.
minifreek
Quote from: TheBoy on 05 April 2016, 18:14:42
Incorrect.
Elaborate..... instead of just saying incorrect.... :y  :P
D.I.L.L.I.G.A.F...
Quote from: minifreek on 06 April 2016, 12:55:44
Incorrect.
You were quoting the procedure to re-synchronise an already programmed remote fob. It doesn't work on a fob that the car isn't programmed to. It doesn't affect the immobiliser at all.
minifreek
There you see, thats a much better answer :y
D.I.L.L.I.G.A.F...
Quote from: minifreek on 06 April 2016, 15:50:49
It has been covered before. In this thread.
