school boy error
Started by Andy B, 04 April 2016, 19:34:53
Daughter phoned me at work today to tell me that, she'd Googled the noise coming from her caar when braking & decided that she needed new pads. So my task when I got home was changing a Siecento's brake pads. She was right, it needed new pads because one of the pads had stuck so the opposite pads was almost down to the backing plate.
While pushing the pads back I noticed something wet dripping from the drive shaft ....... completely forgot about the master cylinder level  :-[ :-[ :-[ Pads changed in about 20 mins at most ...... another 10 mopping up brake fluid  ???
If only its 'fan belt' was as easy! PITA   ??? ??? ??? ???
Easy done, Andy....but how did you compress the piston with the master cylinder cap on?
Quote from: STEMO on 04 April 2016, 19:38:44
The air came out of the same hole as the brake fluid did  ::) ::)
Quote from: Andy B on 04 April 2016, 20:12:55
Oh. School boy error that mate.   ;D
OH you rebel Mr Beans......now, 100 lines.
'When retracting brake calliper pistons I must open the bleed nipple first'
Quote from: Marks DTM Calib on 06 April 2016, 08:51:30
You are of course correct ..... it was a time thing.  :-[ And the addition of new fluid could only have been a good thing.
I must open .........  ;)
zirk
Put a tube on the Bleed Nipple, capture the fluid in a jar, screw top on, label it 'Eco Friendly Recycled Brake Fluid 100% Tested', wack it on eBay, some Mug will buy it.  ::)
Quote from: zirk on 06 April 2016, 11:24:11
You don't even need used oil, just empty jars will do  ::) ::)
http://www.independent.co.uk/news/uk/home-news/man-sells-british-fresh-air-to-wealthy-chinese-elite-for-80-a-jar-a6857461.html
zirk
Quote from: Andy B on 06 April 2016, 12:59:57
Quiet right too, we buy enough of their Rubbish.  ;D
Quote from: zirk on 06 April 2016, 13:11:04
The astute will realise that we ship enough air back in empty shipping containers, and someone else pays. Just need a bottling plant in Tianjin to empty the air into jars. :y
Quote from: Kevin Wood on 06 April 2016, 13:51:30
If trade keeps on increasing, all the air from here will end up in China and we'll get all their smog.  :(
