timing chain longevity
Started by raywilb, 06 April 2016, 11:15:49
raywilb
how long is the life of timing chains. my window cleaner has just rang me asking if I know of any cheap motors for sale. apparently his Astra car has broken down with a snapped timing chain. he cannot even change a bulb so was not aware of what had happened so kept trying to start it. but the call made me think what can I do so I'm never in that situation. if anything ? :-\
Which engine did he have.
Timing chain life is very dependent on design and how well serviced they are
Regular oil changes, neglecting the oil, letting it clog up and reduce the lubrication it what kills them I hear, as a tiny drip of oil lubes the chain.
I suspect your window cleaners Astra had 20k oil changes all it's life, maybe worse.
raywilb
Quote from: tunnie on 06 April 2016, 11:25:35
he starts it on a morning & that's it. I'm always telling him to get the gear for a service and I,d do it for him. he never has.
Chains in crankcases don't need much(if any) extra fed lubrication, but a good supply of pressurised oil to the hydraulic tensioner is critical for it to work, let alone be durable. Once the tensioner stops working as designed bad things happen.
Bigron
I've commented before, so I won't go into detail, but if you are interested, look up how the Morris Minor/Austin A30 engines (BMC A series) used to do it - perfect!
Ron.
Varche
I was talking to quite an educated person(woman) and she forgot to service her car (Land Rover discovery) for FIVE years.
Quote from: Bigron on 06 April 2016, 11:55:32
Ron.
A rubber coated flap is only going to be of 'use' when the chain is on an OHV engine and very short. And A/B series never have noisy timing chains do they? Better OHV engines have hydraulic tensioner; just look at any of the  Rootes 4s.
Bigron
Yes Nick, I agree. After I posted that, I Googled the Minor engine and saw the silly tensioner you are referring to, but that differs from my memory of an A30 engine I had in which the Reynolds tensioner was a neoprene slipper arrangement force-lubricated via a centre hole. The pumped oil also tensioned the slipper by putting pressure on a piston that forced the slipper into firm contact with the chain.
That piston had a notched, spiral groove in it to prevent its return by more than a small amount, thus ensuring permanent contact, and as wear took place it notched around one more step.
Now, I didn't imagine all of the above, but I cannot find details anywhere on Google - am I going mad or can any Oofer confirm (NOT the madness, the description!)?
Ron.
Viral_Jim
Quote from: raywilb on 06 April 2016, 11:15:49
I ran saabs before moving to the mig. Their Achilles heel was oil starvation caused by problems with the breathers. That said, if correctly serviced the chains had a very long life - I'm given to understand that 200-250k was usual on the 2.3T engines. Certainly the last one I had (bought at 160k sold at about 190k) showed no signs of chain wear.
In short, change your oil regularly and listen for any rattle from the chain - particularly on a cold start. Also, a bit of googling will highlight if a particular car model has issues. For example I think some of the Jag v8's from around  1997-2000 had plastic chain tensioner/guide parts that could fail and a number have been replaced under warranty.
ronnyd
Couple i used to work with both ran cars and neither realised that they, the cars that is, were fitted with a dipstick. ;D
omega2018
timing chains are pretty strong it will take a lot to destroy one but they do 'stretch' with age and wear - the links don't actually stretch but wear the causes the chain to get longer as the links get further apart, causing timing issues - cam timing gets retarded.
Viral_Jim
Oo, that reminds me, any Saab/GM 2.8T (looking at you M'lud Opti) can suffer stretched chaos screwing the timing.
Lots of info on the insignia vxr fora about it.
Broomies Mate
Quote from: jimmy944 on 07 April 2016, 22:49:50
Good advice for the VX crew - I believe from UKS it wasn't an issue on the Saab after they revised the guide setup.  :y
Viral_Jim
Ah, good knowledge! I only vaguely know about the 2.8T, 2.3T is my power plant of choice, but only because of the car it gets attached to.
Once again GM taking a Saab idea and making it worse :P.
