Induction Hob, Pots, Pans etc Question.
Started by zirk, 06 April 2016, 16:46:18
zirk
OK, new toy, well new for me, so first thing I do is to test what pans I already have, Google says anything magnetic will work, but dont use cooper or metal thats not magnetic.
So, out with a speaker magnet, Omega Bose Sub if you must know, and sadly most pans fail the magnetic test, but zirk being zirk, thought I would test some of the non magnetic ones, an sure enough most work, Stainlees Steel Wok and some Cooper based ones heat up water a trick, despite failing the magnet test.
So what the crack here, is it a case of if it works, it works, or am I likely doing damage to the hob but not using the recommended pans.  :-\
zirk
Quote from: STEMO on 06 April 2016, 16:59:20
Cooking is a pink job, apparently  ;D
Not in my house, well, not if you want to eat something edible anyway.  ::)
Migv6 le Frog Fan
A question more suited to www.womensinstitute.com    :y :D
zirk
Quote from: Migv6 on 06 April 2016, 17:06:34
Yes, well thanks for that, you can go and **** yourself as well,  ;D  ;D
Common materials include stainless steel multi-ply, stainless steel with a ferrous base welded to the bottom of the pan, cast aluminium
with ferrous base, mild steel (black iron) and cast iron. If your copper pans have a ferrous content, they`re perfectly acceptable to use. Any pan with a ferrous content will heat the contents quicker than pans with no ferrous content.
zirk
Thanks Rob, first sensible answer Ive had,  :y
Did some more tests, did you know if you put hand between the hob and the pan that..... well, what can I say.
Quote from: zirk on 06 April 2016, 17:40:44
Did some more tests, did you know if you put yer old fella between the hob and the pan that..... well, what can I say.
:o   :D   ;D
Is that a kitchen appliance? Sorry, I'm not sure where the kitchen is, so you appear to be talking gibberish ;D
If you're really attached to your pans, you can use one of  these Basically a ferrous plate with a handle on that goes between hob & pan  :y :y
Kinnell. The things you learn on here.  :o
Quote from: STEMO on 06 April 2016, 18:09:41
Yep ffs don't stick your knob on the hob!  :y
Quote from: Sir Tigger on 06 April 2016, 18:11:55
Oooooo.......I hadn't thought of doing that.....hmmmmm...... :-\
zirk
Quote from: TheBoy on 06 April 2016, 18:05:27
The Kitchen is the one thats full engine bits and crapped out batteries in any sensible house.  ::)
TD
Yes you do!.....Its the room that holds the engine parts cleaning machine  :y ::)
