Just done a speed test on my phone
Started by STEMO, 06 April 2016, 18:23:45
It was slightly faster over 4G than wifi.  ;D
zirk
On EE, 4G here is normally about 7Mbs down and 2 up, on 3G (HSDPA) about 14 down and 6 up.  ::)
Evil Everywhere here is generally about 28Mbps, wifi about 20Mbps (mostly likely due to number of wifis in this immediate area).
I occasionally see similar to Zirk at work, where 3G is faster than 4G.
I clocked 90mb on 4G on EE at the office  :o
I was actually commenting on how shite my wifi is, not how good 4G is.  :(
TD
Quote from: STEMO on 06 April 2016, 19:33:28
Try the same test with whatever plugged into the router....not using wifi.....if its many times faster than that proves your router's wifi is shite.....then consider buying a better wifi router  :y
Not unusual - my wired PC easily manages 60Mbps, even with all the OOF server traffic.  But my wifi bottoms out at about 20Mbps, despite the actual wifi headline speed being 300Mbps.
Quote from: TD on 06 April 2016, 19:41:01
Worth making sure you are on a free or co-channel (in that order) first, and not badly on an overlapping channel, before splashing cash :y
On 2.4Ghz, that effectively means Ch1 or Ch6, and maybe Ch11 if really lucky.
I can see 50+ Wifi networks on 2.4Ghz from where I'm sat now (admittedly 3 are mine ;D), so no chance of a free channel, but found 1 that just has co-channel. My other 2 wifi networks are on overlappers :(
I haven't got a clue what you're talking about. It's a sky router with the sky box plugged in and everything else on wifi. That's only three iPads and a laptop though.
TD
Quote from: TheBoy on 06 April 2016, 19:57:16
Or 13 if your be naughty  :-X
biggriffin
Quote from: STEMO on 06 April 2016, 20:01:24
You should know by now, that any mention of, computing, software,etc gets un-Intelligible replies, in ott gobbledygook. :D
Hoof'land storeman.
