barrier cream
Started by omega2018, 15 April 2016, 02:13:41
omega2018
does no one use it now, is everyone wearing gloves?  can't seem to find a known brand that is for cars and not babies bums.
zirk
I use gloves now for all sorts of work now, but on the occasions that I do use barrier cream then Deb / Swarfega Pre Work.
You big girls*
*I know, I know. Day in, day out and you'll end up with skin cancer or at least psoriasis.
I've found the black nitrile gloves to be pretty good if I'm doing really greasy stuff (like packing bearings), otherwise I tend to wear these: http://www.mechanix.com/automotive/the-original
You can find them in the UK about £20 a pair and they're the only gloves I've found that fit really well and let me pick up washers etc without fumbling; even the light 'cut proof' gloves make me drop stuff.
They're also warm which is handy when the ambient temp is low and your tools feel so cold you think they might stick to your skin.. ;D
At the last place I worked, we had this stuff PR88 Not cheap, but you only need a little bit each time. It worked well, though its draw back was if you got your hands wet when doing the job.
I have both cream and gloves, but normally forget to use either until I'm elbows deep in oil. ;D
Quote from: Kevin Wood on 15 April 2016, 11:40:08
I have cream and gloves too, Kev, but I don't work on cars.  :)
Quote from: aaronjb on 15 April 2016, 10:42:34
I wasn't impressed with the Mechanix gloves at all; got them wet a couple of times and they fell apart. I do keep disposable gloves, but only tend to use them when using paint/filler/chemicals or like Aaron when doing greasy stuff ; this is mainly so I don't leave greasy fingerprints over the paintwork/interior/tools/doorhandles/toolboxes/house/taps/cat.
The problem I have with gloves is finding them to fit; I have wide palms, and short fingers. When you're wearing gloves just to keep warm, it's merely annoying for your fingers not to reach the end of the glove. When working in them, that is really difficult.
When I want protection from rough edges, splinters etc I find that these  http://www.skytecgloves.com/skytec-aria#.VxDY0TArKM8are good. I bought a dozen pairs for a tenner, and they fit me well and last for ages.
I'm the same, much to her annoyance.
And always seem to get itching Gentlemen Parts when I am covered in grease....
X30XE
Kimtech purple nitrile.
The only wall to roll  ;)
Omegatitis : [in remission]
Quote from: STEMO on 15 April 2016, 12:20:58
I don't need to know why. ::)
tigers_gonads
Quote from: TheBoy on 15 April 2016, 17:03:47
:o :o :o
I'm not surprised  ::)
Try a water based lub next time   ;) ;D ;D ;D
zirk
See, this is what happens when you introduce Trade Club into the Bedroom area.
