Author Topic: Autobox soloniods wanted for 3.2  (Read 5013 times)
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« on: 17 April 2016, 11:38:34 »
Strugguling to find any If anyone canone can help?
amba
  • Medway towns
    • German V6
Re: Autobox soloniods wanted for 3.2
« Reply #1 on: 17 April 2016, 11:51:11 »
Fro memory..which is sometimes sketchy :D..think JPat sell them along with filter and sump pan gaskets .Worth finding there website then checking ..hope that helps :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 17 April 2016, 11:53:00 »
I'd imagine they are the same across the autobox range. I changed some on my old 2.2 and found it a little tricky but it did the job for a bit but went again, maybe new would be better
ted_one
« Reply #3 on: 17 April 2016, 13:39:00 »
I'm pretty sure amba is correct about JPat,did check them out a couple of fubared transmissions ago  ::)
« Reply #4 on: 17 April 2016, 15:38:18 »
http://jpat.co.uk/2013_Cat_General_Motors.html
24421E............Solenoid, 4L30E 1-2 & 3-4 Shift
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #5 on: 17 April 2016, 17:35:27 »
Thanks for the link Rob. What code do I click on?
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #6 on: 17 April 2016, 17:36:20 »
What code do i click on Rob? :y
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #7 on: 17 April 2016, 17:40:06 »
Found it. Thanks guys. :y
steve6367
« Reply #8 on: 17 April 2016, 18:53:06 »
From experience be very careful with the roll pins - I broke mine off which then dictates that you have to remove the valve body.  :-[
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #9 on: 17 April 2016, 22:35:35 »
Think they shout abou £80 a valve  :o :o
Steve B
  • Leicestershire
« Reply #10 on: 17 April 2016, 22:47:50 »
Thought it was just the 2-3 you were after  :-\
« Reply #11 on: 18 April 2016, 11:18:43 »
I have a full set of known good ones here, I just need to remove them :y
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #12 on: 18 April 2016, 12:21:15 »
inboxed you mate.
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #13 on: 18 April 2016, 19:32:05 »
All ordered! Cheers for your help.
