Corsa tyres.
Started by Field Marshal Dr. Opti, 20 April 2016, 11:54:14
Any problem replacing standard fit 185/55/15 with 185/65/15?
The ride on the standard tyres is 'crashy'........and the 65 profile tyres are significantly cheaper. :)
Any advice, chaps.
Only the possible insurance implications really... Is it one of the option sizes?
Quote from: Lazydocker on 20 April 2016, 11:57:09
Not sure if a '65' profile tyre is listed as an option.
I'm guessing it will raise the gearing slightly. Hopefully the ride would be improved.
Obviously there would be a slight under-read on the speedo too :y
Shouldn't be a problem if I sling a set of 65 profile tyres on.
Quote from: Doctor Opti on 21 April 2016, 12:35:39
If it's a size quoted in the manual for wheels of the same dimensions (diameter x rim width) then happy days... :y
Quote from: Harris K Telemacher on 21 April 2016, 12:38:23
Al.....I don't have the handbook to hand.
The 65 profile tyre has a larger overall diameter so I wonder if it may rub.
There is a lot of leeway for tyre and wheel widths, so I wouldn't worry about that. For instance, going back a few years, the tyre manufacturers suggested that a 205/60x13 tyre would fit a wheel between 5.5" and 8.5"! Not that it works very well at either end of that range.
If the 65 profile tyre is a standard Corsa size then they'll be fine. It's hardly a massive difference anyway.
The middle number is a percentage of the width (first number). So 55% of 185 is 101.75 and 65% is 120.25, that's quite a difference.
Quote from: STEMO on 21 April 2016, 15:10:09
And why wheel width has a bearing..
There isn't a standard as to how you measure that 185mm(or whatever) so the actual width varies across different tyre brands.
Quote from: Nick W on 22 April 2016, 00:40:53
Yep.....I was amazed to find that a 235/45/17 Goodyear Eagle F1 was about an inch wider than the crappy 235/45/17 Michelin Primacy it replaced.
That clears things up nicely.  ;D
Toledodude1973
I was lost 3 posts back :D
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Happy with Dunlop Blueresponse... similar size, 195/65/15 V88, done about 1,100 miles and grip well in wet, dry,damp and frosty conditions, and reasonably priced :y
