Auxiliary belt snapped and best shocks to buy
Started by thebeast, 23 April 2016, 10:31:18
thebeast
Just seen an omega for sale said auxiliary belt snapped may be a pulley seized it's worth a gamble, also looking to replace my shocks any recommendations
biggriffin
I've just bought a pair of shocks' from Poland £28.00 delivered, (rears) fitting kit not much good.
Hoof'land storeman.
thebeast
I have seen a set Bilstein on eBay all for front and back for £177 has anyone tried them?
Quote from: thebeast on 23 April 2016, 10:31:18
Aux belt or cam belt
thebeast
terry paget
If it's only aux belt, you just need new pulley and belt, £50 the pair. Only snag is you can't drive the car home.
thebeast
Yes but which pulley that's the hard part
Quote from: thebeast on 23 April 2016, 12:26:30
probably the plastic tensioner pulley, as that's the usual failure on serpentine belt systems. A new one costs a tenner.
If it isn't that then it will be a seized AC compressor(or knackered clutch) or the water pump which will also be leaking like a politician.
thebeast
It's a gamble I am taking as the belt snapped it took out a few sensors and coolant pipes so I am kinda in 2 minds  :-\
Quote from: thebeast on 23 April 2016, 12:52:32
With the belt off, it should be obvious which pulley caused it to snap... strong money is the tensioner pulley... but spin them all and see if any are rough/seized and go from there... wiring is easily repaired and coolant hoses easily replaced, so shouldn't take too much effort to keep it going ;)
If it took out pipes and wiring then it may have got into the cambelt as well and caused that to jump some teeth  :-\
Webby the Bear
Quote from: Andy H on 23 April 2016, 13:25:48
Not wishing to be pessimistic but I was thinking exact same thing.
RIP Paul Lovejoy
Ever Ready
What's it going for? could be a worth while buy either as a daily or as a donor car.
Bought a Vectra years ago with a snapped timing belt (Water pump froze solid due to ne anti-freeze) new belt, three second hand cam followers and could have sold it half a dozen times.
An ounce of experience is worth more than a pound of enthusiasm.
thebeast
frostbite
The auxiliary belt on my old cdx snapped while driving. Gave me a shock lost PAS and on a roundabout
e46 325i se - 1.8vvti avensis liftback
