Fuel filters
Started by Webby the Bear, 23 April 2016, 22:42:45
Quote from: Marks DTM Calib on 25 April 2016, 10:29:38
I know of a few vehicles where they lacked grunt at higher revs, in both cases it was a clogged fuel filter limiting fuel delivery.
The Corsa ones tend to rot through if not changed to!
Hmmm, that got me thinking....   ...but we changed the fuel filter on the Bus IIRC?
Quote from: TheBoy on 25 April 2016, 17:11:58
is there another one in the tank?
frostbite
There should be a strainer around the pickup
e46 325i se - 1.8vvti avensis liftback
Quote from: Andy H on 25 April 2016, 18:03:16
Absolutely no idea.  I know Mr DTM has a few theories about its (lacklustre) performance....
Webby the Bear
Is there really anything in this supermarket vs shell/bp etc? I'm not talking about super vs regular. I mean Morrison's regular 95 vs shells regular 95?
Both our cars have always had Morrison s fuel
RIP Paul Lovejoy
Quote from: TheBoy on 25 April 2016, 18:50:11
Park in front of the garage... That should speed it up a bit :-X ::) ::)
Quote from: Webby the Bear on 25 April 2016, 19:29:30
Not surprised, it's cheaper than water at that Morrisons (assuming it's the one I think)! ;D
TBH I think you might be 'more likely' to get a tank of filter-clogger from a supermarket, but unless you're unlucky I doubt there's any real world difference.
Noticeable difference with diesel
frostbite
Was it not morris ons that had high silicone contamination  and ruined a few cars?
Just to save some on there fuel order. Buy cheap get cheap
Quote from: Marks DTM Calib on 26 April 2016, 08:08:30
Very much so - even ignoring performance, look at the smoke in mirror at night when using supermarket diesel.
Before MOT, I always put a couple of tanks of BP/Shell fuel in to reduce the smog output.
Now I'm assuming the smog is unburnt fuel, so clearly get a better burn with non supermarket stuff.... :y
in the Zafira, I get about 100 more miles to the tank using shell than Tesco's, and about 60 more than using morrisons.
My usage is pretty samey.....and enough to make me now only use Shell.
Webby the Bear
100 more miles per tank??? Now that is significant !!!
Do you think this would apply to petrol also?
RIP Paul Lovejoy
Shackeng
I definitely get better performance on the TD using BP diesel vs Tesco's.
biggriffin
Quote from: frostbite on 26 April 2016, 09:37:44
Was most of the fuel companies, the amount of silicone was to much,and killed lambdas', silicone is added to reduce frothing, and a lubricant, for in tank pumps.
Hoof'land storeman.
baggers
I have come across a few cars that wouldn't run very well on Morrison's 95 a bit lethargic and poor idling, changed to a branded fuel and always fine.
