irmscher sportstars
Started by pauls, 25 April 2016, 14:48:20
pauls
I have just picked up a set of these and noticed a lot of old glue marks from the wheel weights. Any recommended way of safely removing this. I was thinking of petrol and a bit of hard plastic.
Quote from: pauls on 25 April 2016, 14:48:20
Tar spot remover and elbow grease :y
Soften the glue with acetone and scrape the worst off with a plastic scraper. Gentle rubbing with some very fine scotchbrite and some more acetone will remove the rest.
frostbite
Heat it with a hair dryer as if you were debadging
e46 325i se - 1.8vvti avensis liftback
minifreek
D.I.L.L.I.G.A.F...
pauls
frostbite
What offset are they?  I seen most for fwd applications
pauls
Quote from: frostbite on 26 April 2016, 09:31:43
The et on mine are 30
Sereks ones are 30 as well
Omega uses ET30 Sportstars.
They are quite soft, thought not as bad as MFL MV6 ones, so be prepare for regular refurbs given current road conditions  >:(
frostbite
Do they buckle easily?
The v70 would dent it's rims on the wrong tyre height, quite sad really
Quote from: frostbite on 26 April 2016, 19:08:46
Never seen one buckle (or an MFL MV6 wheel buckle for that matter either). But they do get flatspots quite easily if you're unable to avoid broken road surfaces at speed.
