Oil filters where's me VOF 93??
Started by Diamond Black Geezer, 27 April 2016, 16:11:01
93156954 VOF 93 is now replaced with
95509857 which is termed a 'longlife' filter. Huh? Doesn anyone know what they mean by 'longlife', and what the recommended intervals for this is, then?
Though I can see the sense in such a device, given that I'm ideally changing my oil every 6 months anyway, I don't really need, or care about a 'longlife' filter for more money. Unless someone can safely say that I'm fine leaving this is once every other oil change, for instance?  :-\
biggriffin
Mountain and mole-hill,  :)
Same filter just rebranded to keep tree huggers happy.
Hoof'land storeman.
Won't make any difference to me as oil filters generally turn out to have a long life anyway!  :o  ::)  ;D
haha. So basically same filter, 2.6 times the price, called 'save the whales' and still replace every oil change, yeah?
dear, oh dear, Luton...
Quote from: Diamond Black Geezer on 27 April 2016, 16:52:38
How much now?
frostbite
If it's the spin on canister why not get a longer one that's used on diesels then it will be longlife or every second interval
e46 325i se - 1.8vvti avensis liftback
they were £1 on TC, now £2.60ish for the 'new improved recipe'
biggriffin
Quote from: frostbite on 27 April 2016, 18:03:57
False economy.
Hoof'land storeman.
frostbite
Ah have but it will have slightly raised capacity to compensate for the extra interval
You'll also have a small collection of iron filings to make pretty pictures with
Quote from: frostbite on 27 April 2016, 22:39:52
All pretty irrelevant if you change it every 5-10k miles ???
Only noticeable difference would be the extra cost...
A longer filter body might make it easier to fit/remove, but then again, unless you have already done the spin on conversion or own an earlier car, you won't be able to fit the larger filter anyway ::)
It's an update re: current TC prices, anyway.  :)
I'm sure I've got a couple knocking around :-\
biggriffin
£1.79 from ecp, and there's 20% off till Monday, and oil is on bogof.  :-X. Simples.
Hoof'land storeman.
Quote from: biggriffin on 28 April 2016, 14:27:43
£1.79 from ecp, and there's 20% off till Monday, and oil is on bogof.  :-X . Simples.
You can't say that here!! The use of pattern parts will bring about TEOTWAWKI, and it will be your fault.
biggriffin
Quote from: Nick W on 28 April 2016, 14:40:36
You can't say that here!! The use of pattern parts will bring about  ;D, and it will be your fault.
You been sniffing thinners in a confined space again  ;D
Hoof'land storeman.
