Author Topic: Wiper Settings gone up the wall.  (Read 3180 times)
REvil71
  • Wales
    • 3.2 Elite Saloon
« on: 27 April 2016, 16:12:45 »
Hi.
I hope someone can help me.
My wipers have stopped working properly. I have the rain detector on the top of the windscreen
and now I have found the first setting - windscreen rain doesn't work. The second setting which is
occasional doesn't work. The only one that works is constant and quicker.
I recently had work done on it where the battery was disconnected. Is there a relay reset like the windows
and sunroof or is it more terminal.
Thanks for anyones help with this....... :'(
REvil71
  • Wales
    • 3.2 Elite Saloon
Re: Wiper Settings gone up the wall.
« Reply #1 on: 23 May 2016, 15:39:28 »
I have now found out it is a fault that needs clearing with a teck2.
Can it be reset without this or have I no option.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 23 May 2016, 15:43:23 »
Shouldn't need a Tech 2 to reset it, although a Tech 2 session might help to diagnose the issue, think I would be looking at Relay, Stalk connections, and or Rain Sensor itself working correctly.  :-\
« Last Edit: 23 May 2016, 15:46:03 by zirk »
« Reply #3 on: 23 May 2016, 16:10:33 »
Bugs and stonechips being the easiest starting points
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #4 on: 23 May 2016, 16:17:03 »
Cheers. That's where I will start then...
« Reply #5 on: 23 May 2016, 16:26:38 »
Oviously over the sensor, rather than randomly...
« Reply #6 on: 23 May 2016, 18:03:45 »
Tech2 wont help, its not an ECU controlled system.
Its virtually identical to the earlier, variable type fitted to all earlier cars, with the variable resistor being replaced by the rain sensor. So its a case of using a meter.
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #7 on: 24 May 2016, 18:35:44 »
Also when I squirt water, the wipers don't come on so possibly relay.
« Reply #8 on: 24 May 2016, 18:40:09 »
Or switch...
« Reply #9 on: 24 May 2016, 19:40:49 »
Given the symptoms, I've be looking at stalk itself, or the connector/wiring around the stalk.
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #10 on: 27 May 2016, 19:13:23 »
Checked relay. nope.
so next is stalk to test.
